F2 motor into a 6080 |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2909 |
Topic: F2 motor into a 6080Posted: 30 Sep 2026 at 7:58pm |
Motor tag needs to reference 433T correct? Front plate needs to be swapped correct? How bad of a winter project?
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3793 |
Posted: 30 Sep 2026 at 8:33pm |
F2/F3’s had 433I. K2’s had 433T.
6080 had 433I. Edited by AC7060IL - 30 Sep 2026 at 8:39pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7720 |
Posted: 5 hours 16 minutes ago at 2:55pm |
Basically they are both the same engine. Yes, the front plate would need to be switched to accommodate the hydraulic pump. Intake manifold might also need to be switched so you have an intake heater. Never did the swap, but probably just have to move some stuff from your old engine to the combine engine.
