Eureka Springs run
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Eureka Springs run
    Posted: 20 hours 3 minutes ago at 5:28pm
Wife and I had decided back in Spring to take another run to Eureka Springs, this time in the Camper rather than a Hotel.  So off we went last Sunday to The Kettle Campground, just at Eureka Springs City Limits.  When I made reservation there was ONE Pull Thru large enough that was not booked so took it on faith would work.  It DID.
Sadly old RV AC did NOT for long, temps rose over 86 and the mechanism would cease cooling, go into Overdrive and then amp out trip breaker.  Learned to manually cycle and adjust temp at T-stat to maintain function until Last Evening.  High hit 94, Sun set was aimed directly at Roof Unit, Humidity crossed a narrow line to 87%, could not get to cool below 85 until close to 9pm, then coaxed to 80 and left there for the sleep hours.  Awoke twice and dropped temp into 70s where it worked but wife was done, we had 'The Talk' Came home this morning.
Will be on the RV Roof in early hours tomorrow, inspecting the External systems and wiring, perhaps have a nest of sorts sucked up to Condenser, doubtful but will go there.  Then will pull lower cover and inspect for Cross Flow Hot to Cold Side, see if have lost seals along those boundaries and finally if nothing found, ID the BTU, a Model number and see what I can get to replace this.  Couple other small issues but nothing cannot handle simply and here.
Pics of the Site and map to position.  LOADS of Loblolly Pines along the site routes, was a test of my abilities to access and egress, was just fine.
Would be On the Harley at 8-9am, be in  Restaurant, Shops, or a 'Lounge' prior to getting to Smoldering hot.  By 1pm would be back in camp to pool swim or to stroll about under the shade.  Rode thru much of Town, areas seldom visited as streets Narrow and STEEP, back to the Crescent where we stayed in 2010, lovely old Hotel, haunted BTW, Beaver Lake, the Golden Gate of the Ozarks and a few chosen spots we remembered and are still active as Pied Piper and Cathouse Bar and Grill.  The ABSOLUTE BEST Breakfast Bloody Mary money can buy.
Edited by DMiller - 19 hours 60 minutes ago at 5:31pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 44 minutes ago at 5:47pm
Wish I had known. I would have stopped by to say hello.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 40 minutes ago at 5:51pm
If ever you come visit again let me know and I’ll ride a few miles with you if you like.
Usually has to be a weekend for me to ride much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 60 minutes ago at 6:31pm
We get down at least once every few years, sometimes twice a year!!  Will make it a point to call.
Did have one FUBAR Moment at War Eagle Mill, hit a point of Rock sticking up in parking area, tall enough to catch the return spring on the Harley "Jiffy Stand" or Kick Stand, was swinging free, managed a piece of Wire from the Mill and had it sewn up enough to ride into Pig trail HD, fixed in under two hours.  Just at $100 labor and spring.
Edited by DMiller - 18 hours 56 minutes ago at 6:35pm
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 32 minutes ago at 11:59pm
 Hey Mr Miller,,likewise what THAD says,,,i'd a liked to meet up to get a good look at your rebuilt KW,,,when you was in Eureka Springs,,,,and,, you are correct,,,it has been mighty HOT and Muggy in these parts,,,,don't get to  see ole Thad much these days as he does work lots of hours.
 Happy trails back home,,,,
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 45 minutes ago at 10:46am
Joe! Nice to see you on here. So…..makes me wonder…..are you living in AR now or still just visiting. From time to time? Yeah, I’m nosy. But just wishing you well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 26 minutes ago at 11:05am
Hey Tbone, was just contemplating same thoughts.  And yes already back to house, researching RV AC.
Edited by DMiller - 2 hours 25 minutes ago at 11:06am
