Early wd Torque housing seal
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: Early wd Torque housing seal
    Posted: 24 Mar 2012 at 5:31pm
  I am restoring an early wd, and was going to reseal the torque housing today, but ran into a snag.  It has the updated double seal, spacer and adapter on the shaft.  In the past I've been able to use 2 seals back to back with no problem, but the housing must be thinner on this early one where it retains the seal.  I can tell on the old seal that it was only pressed in about half of its depth.  Does AGCO still make this double seal?  Their part # is 702715922.  If anybody would have a national or other aftermarket number that will work too......Thanks
This page was generated in 0.115 seconds.
