Dr Allis |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2080 |
Topic: Dr AllisPosted: Yesterday at 7:30am |
Question for Dr. Allis or anyone who has knowledge of this.
How do you mount an Allis #3 mower on a CA with a snap coupler, the mower came off a CA with pin hitch. I have found a video of some one mounting a #3 on an H farmall????
Posted: Yesterday at 7:34am |
Sorry. Can't help you. B-C-CA tractors didn't exist in my area.
Trinity45
Posted: Yesterday at 9:49am |
Thanks, I have seen one now using a 3pt modification, one on a B, one on a H farmall but can't find a newer CA mounted one.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5220 |
Posted: Yesterday at 11:53am |
The parts book or an operatetors manual will show the different hitches for different tractors. I'm not where I can look at the books for the #3, however I do know that on a #5 the same main hitch is used for the PinHitch and SnapCoupler tractors with a few extra straps for the SnapCoupler.
PaulB
Posted: Yesterday at 1:27pm |
here's the page from the parts book. Nothing is shown as different from the PinHitch to the SnapCoupler tractors. However from what I see here and knowing the differences the rivet (#4) should go through the furthest hole for the rockshaft which you will not have on a snapCoupler tractor.
The CA PickUpPlow manual shows how to change positions of the rockshaft for lift or drawbar work. You will need to have the rockshaft in the position for drawbar work and remove the lift latches. Using the remaining hole on the rockshaft after removing the lift latches will most likely have the front of the mower too high and a PinHitch rockshaft is probably needed unless you fabricate a workaround. |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2714 |
Posted: Yesterday at 3:32pm |
Paul I did email him the ca hitch pages from the manual.
Trinity45
Posted: 21 hours 13 minutes ago at 6:55pm |
Trinity45
Posted: 21 hours 12 minutes ago at 6:56pm |
The email would not open the attachments, sorry.
PaulB
Posted: 8 hours 46 minutes ago at 7:22am |
Remove both cylinder pins from the rockshaft, let rockshaft lower all the way to vertical and re-pin lift cylinders in to other hole, as shown in many implement manuals.
Trinity45
Posted: 6 hours 4 minutes ago at 10:04am |
for some reason your emails go to spam and when I open them it tells me did not down load attachments?? Just tried the second one. But thanks for trying,
mdm1
Posted: 5 hours 52 minutes ago at 10:16am |
Hey that's fine. Sorry it didn't work.
mdm1
Posted: 5 hours 27 minutes ago at 10:41am |
See if this works from the manual.
Edited by mdm1 - 5 hours 22 minutes ago at 10:46am |
mdm1
Posted: 5 hours 23 minutes ago at 10:45am |
Trinity45
Posted: 5 hours 17 minutes ago at 10:51am |
mdm1
Posted: 3 hours 46 minutes ago at 12:22pm |
I had mine on a WD-45 with a snap coupler. Mine hook up was different than yours. If I remember I would engage the hydraulics at the quadrant and the rear cylinders would go up as far as they could then the hydraulic cylinder on the mower itself would work. WD-45's have two different mounts. Mine mounts on the drawbar and then to the finals. Do you have any mounting hardware at all? Good luck.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1099 |
Posted: 3 hours 23 minutes ago at 12:45pm |
Those pictures do him zero good. He has a snap couple ca. entirely different hitch
Trinity45
Posted: 2 hours 39 minutes ago at 1:29pm |
No, just what you saw in the mower, my snap coupler is similar to a WD just on a smaller scale. I can most likely make a mounting bracket. Just wish I could see one on a CA with a snap or even a picture of a #3 on any snap coupler.
mdm1
Posted: 2 hours 19 minutes ago at 1:49pm |
Hey I just told him I would post what the manual says!!!!!! Don't know why I bother!
Trinity45
Posted: 2 hours 16 minutes ago at 1:52pm |
Your post helped, especially the part on what to do with the hydraulics. I did some google and found a picture of mounting brackets for a D-14 snap couple, which gives me at least an idea what those snap couple brackets look like. Going to Ebay to see if there is a manual I can pick up.
PaulB
Posted: 59 minutes ago at 3:09pm |
I guess you don't know what you are looking at. After seeing those pictures I will correct myself. After you remove the lift latches from the rockshaft and lower it to the vertical "drawbar" position the #3 brackets will pin into the remaining rockshaft holes and be in the correct position. There is no need for the drawbar cross piece to be pinned to the rockshaft and there is nothing that will need to hook into the SnapCoupler bell. If you got ALL if the pieces that came from a PinHitch CA, just lower the rockshaft and put everything in place and go mowing.
Mikez
Posted: 41 minutes ago at 3:27pm |
I think we have some of those bracket part numbers
