Dr Allis
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Topic: Dr Allis
    Posted: 20 hours 7 minutes ago at 7:30am
Question for Dr. Allis or anyone who has knowledge of this.
How do you mount an Allis #3 mower on a CA with a snap coupler,  the mower came off a CA with pin hitch.  I have found a video of some one mounting a #3 on an H farmall????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 3 minutes ago at 7:34am
Sorry. Can't help you. B-C-CA tractors didn't exist in my area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 48 minutes ago at 9:49am
Thanks, I have seen one now using a 3pt modification, one on a B, one on a H farmall but can't find a newer CA mounted one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 44 minutes ago at 11:53am
The parts book or an operatetors manual will show the different hitches for different tractors. I'm not where I can look at the books for the #3, however I do know that on a #5 the same main hitch is used for the PinHitch and SnapCoupler tractors with a few extra straps for the SnapCoupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 10 minutes ago at 1:27pm
here's the page from the parts book. Nothing is shown as different from the PinHitch to the SnapCoupler tractors. However from what I see here and knowing the differences the rivet (#4) should go through the furthest hole for the rockshaft which you will not have on a snapCoupler tractor.
  The CA PickUpPlow manual shows how to change positions of the rockshaft for lift or drawbar work. You will need to have the rockshaft in the position for drawbar work and remove the lift latches. Using the remaining hole on the rockshaft after removing the lift latches will most likely have the front of the mower too high and a PinHitch rockshaft is probably needed unless you fabricate a workaround.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 5 minutes ago at 3:32pm
Paul I did email him the ca hitch pages from the manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 42 minutes ago at 6:55pm
Thanks.  Just wondering what I do with my lift cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 41 minutes ago at 6:56pm
The email would not open the attachments, sorry.
This page was generated in 0.104 seconds.
