Does the ib have a parking brake?
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Does the ib have a parking brake?
    Posted: 08 May 2022 at 4:17pm
Hud, i looked and the lever off the IB will not work on a C or B... The IB has a 1/4 inch thick plate bolted to the final drive housing and pointing forward for the C-channel frame to mount to.  The parking brake lever is mounted to that plate and pivots on a bolt about 4 inches below the 2 x 2 box section that the brake pedals mount to... This plate is not on the B or C... On the IB, the lever is connected to a return spring. Also has a cross plate and sets under the right brake pedal and pushes the pedal forward and you pull the lever back... here is a picture.. not real clear.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2022 at 5:11am
Thanks guys.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 10:09pm
would that lever work on a  c tractor ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 9:15pm
right side, up against the fender... LONG lever...
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 9:06pm
Yes, The IB has a hand lever that pusher the foot brakes forward.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 8:36pm
My B tractor 1/2 came with swivel brackets that serve as parking brakes. However, these won't work on an ib. Did the ib have a parking brake feature?
