Decals on a B
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: Decals on a B
    Posted: 27 Nov 2010 at 9:27am
Well the B tractor I'm doing is ready for decals and now I have to get ready.  The decals I have came from Tractor Supply with no instructions.  I know that they are not the vinyl type and would like helpful advise on installing them. I'm a retired paperhanger of 40 years and hope that helps me but I still would like to hear about someone else's experience.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 11:22am
If they arn't the vinyl, they are the mylar type decals. Just peal the backing paper off, and apply like a sticker or stamp. Sometimes the large "Allis Chalmers" one won't turn out looking too nice with all the plastic around the letters. I went and got a vinyl decal for that one and replaced it.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 11:28am
Fred, Do you need to know where to apply them.  If that is the case let me know I have a book with locations.
Let me know.
Good luck!
Bill Long
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 1:26pm
I'm pretty sure I know where they go as far as that goes.  Thanks anyway.  I'm not trying to make a show tractor but just want it to look nice so if I'm off an inch or two I'm not going to get upset.
I was just concern about the installation as far as getting the decals off the paper and onto the tractor.  When I was working and screwed up a piece of wallpaper it wasn't mine and I always had plenty more to work with but I didn't screw them up too often.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:07pm
 Spray the surface with Windex (not the spray can type } it will give you a little leway just like hanging wall paper use a damp cloth starting in center to push the air bubbles out
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:17pm
I tape them across the top with masking tape to the tractor, then lift the decal up, start pulling the backing off and then press it back in place letting the masking tape help hold in place.  Dave.
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 7:56am
Thanks for all the good replys.  I did it!  No problem.  It was a piece of cake.
I would have no problem doing it again and maybe that's an excuse to get another tractor.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:23am
I try and trim the mylar ones as close the the lettering as I can, they look a little better with out all the extra border showing.
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:32am
Fred, how about a picture of how they look on your B?
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:33am
How about the ones that you soak in water and slide off the backing into place.  I have a set of them that came with the B I bought in 1979.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 11:43am
Waterslide Decals? See here:
You do have to make some minor adjustments from the article, as most waterslide decals are used for scale models, and this is what they are describing in the article. But as far as I'm aware, they apply the exact same way.
