D-19D won't start
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: D-19D won't start
    Posted: 12 May 2024 at 7:31am
First time my D-19D has not started for me in the Spring. Fuel is on and in filters. Someone said the plunger is stuck in fuel pump. Any suggestions on fixing this would be appreciated. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 9:28am
Hi:  Curious as to why the choke lever is pulled all the way back towards the driver?  On mine it is always pushed all the way forward.  I choke mine a little bit (perhaps half way), then push them forward.  They don't ever sit all the way back in the that position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 9:32am
It's the on off lever to the pump. That is the on position. rrhead(SD)
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 10:51am
Take the top cover off of the pump.
check to make sure the shut off lever is moving.
That will stick and cause it not to start.
Just had to do this to a D 15 diesel that had been setting for awhile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 11:42am
Thank you very much! I will give it a try. rrhead(SD)
