D19 Water Pump Rebuild |
PoppaBear
Joined: 06 Jan 2026 Location: N. Illinois Points: 4 |
Topic: D19 Water Pump RebuildPosted: 06 Jan 2026 at 4:22pm |
1963 Allis Chalmers D19, gasoline, wide front, survivor. #13101 New Member here... I'd like to rebuild my original Water Pump to keep the original casting (#134445). I have only found replacement pumps, but no rebuild kits. Also, I'm not sure of the quality of replacement water pumps available. Has anyone rebuilt one of these? If so, what aftermaket bearings, seals, gaskets, and impeller was used? Any details would be appreciated like sizes & part numbers. There is a different style between gas & diesel water pumps. And also between Late and Early Gas models, which is the length of the shaft (ie. Early Gas water pumps use a longer shaft (4-15/16" length) versus the Late Gas (5") is my understanding) I'm pretty handy, and have a friend that can assist with pressing out the shaft, etc. I would like to get the aftermarket parts in advance to make the job easier. In addition, I am planning to replace the water tube, upper & lower radiator hoses, fan belts, etc. Hopefully I can keep the radiator in place during this process. Any other advice would be welcome. Thank you in advance. PoppaBear Northern Illinois 1963 AC D-19 #13101 AC registry listed
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5226 |
Posted: 06 Jan 2026 at 8:11pm |
Call Brenda at Sandy Lake Implement. She got me a kit sometime ago for a D15 Diesel waterpump that a customer sent to me to rebuild
Or there are many places that will rebuild any waterpump you send them, Just get a Hemmings Motor News and look up "waterpump rebuilding"
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1104 |
Posted: 06 Jan 2026 at 9:55pm |
Flying Dutch man does awesome work
Mikez
Posted: 07 Jan 2026 at 7:36am |
Do you have early or late model. Parts book says early has long filler neck on radiator 4-15/16”.
Later model have short
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 593 |
Posted: 08 Jan 2026 at 8:15am |
Early or late model might not apply if engine has been replaced (combine engine)!
PoppaBear
Posted: 09 Jan 2026 at 11:02am |
Update: About to remove the Water Pump. Removed the radiator, and need advice on the Power Steering Pump bracket. Looks like I need to remove the P/S pulley, then the pump, to get the bracket off.... Any advice would be greatly appreciated. Note: This is an Early Gasoline 1963 D-19, S/N 13101.
PoppaBear
Posted: 9 hours 4 minutes ago at 10:41am |
UPDATE: Need to source a Water Tube, bypass for thermostat. Doe's anyone have a source for this part? 1963 D-19 Gasoline Engine. This tube is hard metal, with compression fittings on both ends. Is it shown on page 67, of the D-19 Operators Manual, as Item #1 (shown in photo below). Have a new Radiator, and rebuilt Water Pump ready to install. ![]() |
WeisAC2
Posted: 4 hours 10 minutes ago at 3:35pm |
Alex at A&W tractor was able to make one recently for my D15 diesel. It fit perfectly.
