D19 Water Pump Rebuild
PoppaBear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Topic: D19 Water Pump Rebuild
    Posted: 06 Jan 2026 at 4:22pm
1963 Allis Chalmers D19, gasoline, wide front, survivor. #13101
New Member here... I'd like to rebuild my original Water Pump to keep the
original casting (#134445).  I have only found replacement pumps, but no rebuild kits.
Also, I'm not sure of the quality of replacement water pumps available.
Has anyone rebuilt one of these?  If so, what aftermaket bearings, seals,
gaskets, and impeller was used?  Any details would be appreciated like sizes & part numbers.
There is a different style between gas & diesel water pumps.  And also between Late
and Early Gas models, which is the length of the shaft (ie. Early Gas water pumps use
a longer shaft (4-15/16" length) versus the Late Gas (5") is my understanding)
I'm pretty handy, and have a friend that can assist with pressing out the shaft, etc.
I would like to get the aftermarket parts in advance to make the job easier.  In addition,
I am planning to replace the water tube, upper & lower radiator hoses, fan belts, etc.
Hopefully I can keep the radiator in place during this process.
Any other advice would be welcome.  Thank you in advance.
PoppaBear
Northern Illinois
1963 AC D-19 #13101
AC registry listed
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 8:11pm
Call Brenda at Sandy Lake Implement. She got me a kit sometime ago for a D15 Diesel waterpump that a customer sent to me to rebuild
  Or there are many places that will rebuild any waterpump you send them, Just get a Hemmings Motor News and look up "waterpump rebuilding"
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 9:55pm
Flying Dutch man does awesome work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 7:36am
Do you have early or late model. Parts book says early has long filler neck on radiator     4-15/16”.
Later model have short
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 6 minutes ago at 8:15am
Early or late model might not apply if engine has been replaced (combine engine)!
