D17 Series IV Question
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Question
    Posted: 21 Jul 2018 at 3:56pm
Picked up a non running Series IV D17 gas today,pretty sure the motor is toast.Question
is the motor the same in this as the rest of the D17 models as far as internals and
Horsepower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 4:35pm
Oldest D-17's still had the WD-45 oil filter system. Chassis s/n 24,001 and up had full-flow oil filter.    Engine HP was the same for all series at 63 flywheel HP @ 1650 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 12:58am
Thanks,I have a E Gleaner engine with the full flow system that runs good so I guess
I can put that into the D17 and have about the same HP.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:22am
Yup, but I do believe you will need the governor of the tractor engine. Other than that it should bolt right in
1968 D15D,1962 D19D
