D17 Series iv brakes
Terry McStotts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry McStotts Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series iv brakes
    Posted: 17 Sep 2017 at 8:51pm
I am new to this group, I was adjusting the brakes, the rod was rusted and twisted off. Does anyone know if you can get a new pivot pin block or do you need to get one machined or possibly get the broken rod out and weld and thread the rod? Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 9:02pm
After you get block out, some heat will usually loosen the broken rod. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry McStotts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 9:14pm
Thanks, then cut the rod and thread it and use rod coupling outside of housing with threaded rod back to pivot pin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:12am
On a 180 and 185, the left brake rod has a threaded clevis/yoke on the brake pedal end. It is 3/8" NF threads. If I have a brake rod that I think is going to twist off, I cut off the front end and thread it for the clevis to avoid pulling the rear axle out to repair a broken off rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry McStotts Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 2:48pm
I like that idea, I going to do that! I got the pivot pin out this morning and got the rod out of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 6:08pm
That Dr Allis has all kinds of good trickes up his sleeve !
