D-17 Series 4 governor
SPROEHL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SPROEHL Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series 4 governor
    Posted: 10 Oct 2022 at 10:31am
Help!! I bought a d-17 series 4  around 4 years ago. After a year of service the governor decided to let go. I tore down the engine and retrieved all pieces and replaced them with wd-45 weights which worked for about 2 years then let go yesterday during a hay ride Ouch I retrieved most of the parts still up in the front cavity. Is this a problem that the d-17's have once and a while. Is there anything out there that can replace this outside of the engine (maybe electrical) with a crank sensor or something?
Thanks
Scott
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 3:04pm
I am having trouble figuring out why you would put in WD45 governor weights? If they only lasted 2 years, I can only assume that they were used to begin with. If so, you have no right to complain about them failing.
New ones are available from AGCO and I would replace the pins too as they can accelerate wear as well.
You are dealing with 50 year old mechanical stuff. If you think you can put modern sensors on and have it work properly, go ahead and try - you would probably be the first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 4:48pm
Governor weights and pins for a WC-WD-WD45 and D-17 are all the same. Governor weight explosions are generally considered to be from worn weights and pins and loose/worn/rough timing gears. If you replaced failed parts with used parts, that was probably a bad idea. Any timing gear that has even ONE rough tooth can cause excessive shaking of the governor weights as they spin, which will eventually lead to failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 7:13pm
Scott... Dr is telling you that YES, it is a known problem after 50- 60 years.. You dont want to put in USED parts.. Put in NEW and good for another 50 years... It was a mistake to put in USED WD45 parts ..
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 8:47pm
Any front gear with a rough tooth will destroy Governor weights.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SPROEHL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2022 at 10:52am
Thanks guys for the help on this. I did replace the weight pins and did check for wear on the used wd-45 weights which had a nice slip fit however I have learned my lesson so I will buy new parts to replace. I did notice that both times that I had the problem one of the pins fell out. I am buying new timing gears and governor gear to too try to solve this problem. I also noticed that the camshaft thrust "button" and screw on the timing gear cover were worn so I bought them as well. I need to remove the oil pan again and retrieve the parts there and clean the oil pick-up screen. Has anyone on here removed the crankshaft timing gear with it still in the engine? I have removed the camshaft gear with no problem.
Thanks Again
Scott
