D17 Series 1 hydraulic pump question
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 hydraulic pump question
    Posted: 04 Sep 2023 at 6:16pm
Hey Guys-
So my D17 Series 1's rear lift has ceased function, and the reservoir is low, I added a little bit, and it operated slightly, and the reservoir level fell, and the rearend level went up, so I got the typical blown hose or cylinder seal.
Which I'll make a 'winter project' of... but for the moment, I need it for other things.
The issue I forsee, however, is that the pump is a demand-control device which is mechanically unloaded when pump pressure hits the unloading limit.
In most contexts, this means that a pump that has insufficient source fluid will never reach unloading pressure, hence it will continue to TRY to pump, sans fluid, until there's nothing left of the pump.
I SUSPECT that this might be the case of the D17 Series 1's setup, and I do NOT wish to damage the pump, so what I've done is placed the lift lever in the full DOWN position, and added fluid to the reservoir, to keep that pump wet.
Is this a satisfactory action for the pump's actual operation, or is it unnecessary, or is it futile?  Will the pump burn up ANYWAY, or will it be fine regardless??
I'll be using it with the backhoe attachment for the next two months-or-so, which absolves need for the lift or high-pressure system, because the backhoe runs off PTO pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 7:22pm
normal mode of failure is the hose to the cylinder... or could be the cylinder seal.. Either way, if you DONT MOVE THE LEVER, you should not be putting oil to the hose / cylinder and therefore no oil transfer ......... right ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 7:25pm
Yeah, I got that part, I've watched a few disassembly videos.  I've got SOME fluid in the reservoir, and the handle tied down.  Will that be sufficient to keep the pump safe 'till I finish my digging and shop this piglet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 7:34pm
Should be. Keep an eye on the oil level. Disconnect the line beside the seat and cap it for absolute fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 8:13pm
Ah... excellent... YES!  Thanks guys!
I'm gonna bearings/seals the finals, brakes, and rearend, as well as PTO shaft, seein's how I gotta get in there anyway.  Probably put a diverter/selector on the feed pipe as well, just for future options.  I don't know what it would be, but Murphy's Law says that if I don't, I'll wish I had someday...Wink
This page was generated in 0.348 seconds.
