D17 rear seal
Doobletango View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Topic: D17 rear seal
    Posted: 12 Sep 2020 at 4:20pm
I’m replacing the real seal in the gas engine amongst some other engine work. The one I took out off the engine was rubber but the one that came in my gasket set was felt. Does it matter what it’s made out of?
Also, is it critical that I don’t cut the felt seal to length after getting it packed into the lower half. I did and the manual said not to. I just assumed the supplier cut a length longer than necessary...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 4:42pm
You'd be wrong. Cutting it shorter will make it LEAK. Not gluing it in each groove will make it LEAK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 5:02pm
Ok. Thanks. Guess I need to read the instructions ahead of time...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 5:08pm
Does it matter what I glue it in with? I have black silicone in my shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 6:44pm
I've always used 3M-8001 yellow weather strip adhesive. RTV would not be my choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 7:28pm
I’ll grab some of that this week. Thanks for all the input!
