D17 power steering pump
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering pump
    Posted: 18 May 2017 at 11:16am
I am working on the motor overhaul of my d17 serries 1. The power steering pump is in pretty bad shape. Is there an overhaul kit for these or do I just need to track down all the parts one by one?
I figured I would ask quickly before spending hours looking for all the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 11:31am
Never used to be a kit.....one piece at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 12:42pm
Thanks I will just get the book out and start pulling numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 3:26pm
Wow I guess agco must not want to sell pump parts. I need the governor drive gear and the two gears inside the pump and new bearing and snap rings as the bearing failed and damaged my pump gears. I got a quote for $1414 from agco.
I think my power steering will get a priority flow valve from the front mounted hydraulic pump I added and the orginal pump will be removed.
I am not paying that kind of money to fix a power steering pump.
