D17 Oil Pan Gasket Replacement
Too Tall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Topic: D17 Oil Pan Gasket Replacement
    Posted: 13 May 2017 at 9:50am
I recently replaced the clutch in my late model series IV and tried to replace the pan gasket and could not get the pan to drop down so I foolishly bolted it back up and know it leaks badly. Can you help me with how to do this? Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:13pm
You have pull out the front axle to drop the oil pain.  Assuming you have a gas engine, there are also 2 allen head bolts under the governor that need to be removed to separate the pan from the block.  Putting the new gasket on the pan is also an adventure going around the cutouts for the crank.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 9:38pm
Just one Allen head bolt. If some one replaced the Allen head from the bottom, you'll have to remove the front steering assay.      MACK
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 10:48am
Front end split. Had to do that on my D17 IV diesel when I took off the oil pan to repair a leak in it. Put a 55 gal. barrel under the wide front end and rolled it out away from the rest of the tractor. That seemed to work pretty well. Gatz took pictures of this and posted them, but was a long time ago and don't know where or how to access the pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 1:23pm
Can you replace the front seal at the same time?
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 4:53pm
Yes, it's the best time to do that.  See last pic. Use a quality puller.
And get your cuss-words dictionary out, might need to consult it if ya run short. (JK)
Here's the pix Dave was talking about.  This worked well.  But if yours is a narrow front, you'll have to come up with something else;  support is definitely req'd in either case.
1st pic shows the 55gal drum in position.  Not obvious here is the heavy-duty screwjack that was used to raise and support the tractor minus the front end.  It shows up better in the last pic
It takes a bit of finagling to get things to clear while it's being rolled out.
The P.S. cylinder flange-to-bolster casting developed a leak over the years, and this was the method used to get at it.  The rack was riveted to the rod-end of the cylinder and we attempted to get it separated, but it didn't cooperate.
Permatex #2 was the solution.  IIRC, Dave said it didn't leak after that.
 On edit....
It may sound like the reason for the split was to take care of the P.S. cyl leak.
Not so; The primary reason was to replace the pan gasket as the OP was asking about.
gatz
Edited by Gatz in NE - 15 May 2017 at 7:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:37am
Yeah, the oil pan, prior to my purchasing the tractor, had a large dent in it.  Wasn't leaking at the time I obtained the tractor, but started a year or so later.  Had to remove the pan, to get it straightened out and the hole repaired.  Was really more of a task than what repairing an oil pan should be, but got it done due to the assistance from Gatz.  Glad the form a gasket Permatex worked to fix the power steering leak!  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:52am
I know what Don Bradley would say. Pull the engine and turn it upside down, then follow his instructions in his video...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 5:41pm
Thanks everyone for the info.  It is a wide front so I like the barrel idea.  Mine also has a P.S. leak I hope to find.  It has a AC 500 loader on it that I assume needs to come off?  I am sure I will need more help when I get around to tearing into it.
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:02am
You might be able to leave the loader frame on, one less thing to put back.  My 400 loader is bolted to the frame, not the front casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 1:41pm
Thanks Roscoe.  Do you mean just the frame or can it be done without taking the whole loader off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 4:42am
You will want to take the lift arms, cylinders, and hoses off to give you room to work.
I left the frame that is bolted to the side channels  and rear axles on when I pulled mine.
I also just used a floor jack (not a barrel) to put under the frame and roll it out of the way.  You will need to strap the wheels to the frame as shown in the above photos to keep them from turning when you pull it forward.
- Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:00am
Raise the loader clear up and safety block the cylinders so it can't fall on you. Loosen side frame bolts so you can spread the side frames a little bit when needed. Jack up under the bell housing and loader frame towers. let the fun begin. I'd never remove the loader.....just roll the front support and axle away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 5:17pm
Great!  There is nothing quick tatch about those loaders
