D-17 IV Splitting tips
barnabas_12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 IV Splitting tips
    Posted: 20 Apr 2019 at 6:21pm
Went to split my D17 today, and I've having trouble with the steering shaft knuckle.   The manual doesn't say anything about dealing with the steering shaft, but the gear on the end is not going through the adapter housing.   Am I missing something?    Otherwise, what's the best way to get that knuckle apart?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 6:24pm
IIRR, the best way is to hammer the spring pin out, so only the shaft goes through the hole...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 6:52pm
Drive the lower pin out of the knuckle before you split it. Turn the steering wheel hard to make the rust let the shaft free up/spin loose from the knuckle.  WD40(or the like)  sprayed into the pin hole helps free things up.
This page was generated in 0.127 seconds.
