D17 gas connecting rods |
Putnamd17
Topic: D17 gas connecting rodsPosted: 1 hour 27 minutes ago at 2:35pm |
The book is saying that the pinyon rod needs to be to the left of 2 piston and to the right of the other 2, I’ve never heard of this before and want to make sure I’m doing it correctly, the pin needs to be centered but the rod is offset or are they both offset?
Putnamd17
Posted: 1 hour 21 minutes ago at 2:41pm |
Also piston #1 is the one closest to the radiator correct?
Joined: 11 Sep 2009 Location: illinois Points: 93218 |
Posted: 9 minutes ago at 3:53pm |
#1 is at the radiator... #2 and #3 piston rods have the different offset ... if you put them all in the same way, the center two piston rods will drag.
Posted: 2 minutes ago at 4:00pm |
this is from the WD45 manual--- but similar ... problem is engine design with 3 main bearings and 1-2 between two bearings and 3-4 between the other two..
