D17 died |
WilliamNEOH ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Beloit,oh Points: 40 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Mar 2012 at 6:48am |
about 30 minutes use. Was going uphill, govenor kicked in, turned off the road and depressed clutch to down shift and just died. Back to the house grabbed the 14 and towed her home. An hour later checked fuel line, getting fuel, starting checking for spark and acted like it wanted to start so turned gas on and fired right up. I'm thinking coil, Sound about right. And what is the large nut on the back of the distributor for?
CA,WD-45,D14&D17
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
1944 Allis C
1960 Allis D-17 LP |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
If it happens again pull the drain plug from the carb. and see if you have fuel. If no fuel then it's fuel supply problem or float. Do it right away not an hour later. If plenty of fuel flows then look to ignition.
Edited by Stan IL&TN - 20 Mar 2012 at 7:20am |
1957 WD45 dad's first AC
NickT(Ky) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Elizabethtown, Points: 417 |
My D-14 does that sometimes on a hot day. I think it vapor locks cause I can loosen the fuel cap and the tank breathes. It will start right up after that. On a hot day after a parade I just leave the fuel cap (it is a new one) a little loose.
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
fuel cap should have internal vent, Bob
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Nick did you buy the fuel cap because of this problem or did it start after you got it. It sounds like your tank isn't vented right.
1969 190XT series 3
cornbinder ![]() Orange Level ![]() ![]() Joined: 26 Sep 2011 Location: jeromesville,oh Points: 846 |
i 2nd that motion. sounds like a venting problem.
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
FUEl. in 35 years of working on this junk I have found 1 bad coil. They rarely go bad.
Had to of been fuel because no issues yesterday and it was ran longer than monday.
CA,WD-45,D14&D17
