D15 series II with shuttle (pics) |
elec
Topic: D15 series II with shuttle (pics)Posted: 03 Oct 2026 at 9:25pm |
Just bought a d15 series II. Trying to figure out if the shuttle controlled by the foot pedal is original or after market. I've never seen anything like it before, but parts of it look original and it's hooked to power steering pump. Is it possible it was custom built from the factory? Would like to find info on it so I can fix/adjust it. Thank you
Posted: 03 Oct 2026 at 10:57pm |
Looks OEM to me. Not standard equipment, but an OPTION. I have no idea how to adjust. WHY do you think it needs adjusting ??
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56111 |
Posted: 04 Oct 2026 at 4:15am |
It might be something someone took off of a construction tractor, and installed onto the ag tractor...
elec
Posted: 04 Oct 2026 at 10:09am |
Reason I would like to know how to adjust/fix is because it seems to be too hard to operate by foot. I'm guessing that's why someone manufactured a lever to bypass. If anyone has any info on it would be appreciated.
elec
Posted: 04 Oct 2026 at 10:13am |
Also wondering, it has a PTO, would PTO speed be correct due to shuttle. Has internal hydrolics with snap coupler/power booster and no reverse on shifting lever so appears to be factory. Have more pictures if helpful.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1326 |
Posted: 04 Oct 2026 at 6:29pm |
When it is running, does the pedal have back pressure resistance? Or is it detents like a hydraulic valve?
Joined: 11 Sep 2009 Location: illinois Points: 93377 |
Posted: 04 Oct 2026 at 6:45pm |
pto speed should vary with engine speed... trans and shuttle should have no effect..
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4593 |
Posted: 11 Oct 2026 at 9:33am |
PTO will be non standard 780 rpm with a shuttle. I made a rocker pedal for the shuttle on my I-60 backhoe years ago. It was very hard to snap it all the way in. My current I600 has the factory option two pedal system. push one pedal for forward and the other pedal for reverse. When I press one pedal down, the other pedal returns. Took a bit to get use to but works great.
elec
Posted: 11 Oct 2026 at 12:46pm |
Calvin, Thank you for response on PTO, that's the same info I found online but wasn't sure if it was true so I'm glad to get confirmation.
I put oil in power steering and the system started to work but the bushings are so worn/out-of-adjustment that you can hardly get it to go in reverse without using makeshift handle. Is there a way to feather it so it does not engage so quickly when using it as a loader tractor? I would love to see pictures of how you did a two pedal system. |
Calvin Schmidt
Posted: 12 Oct 2026 at 8:39pm |
The two pedal setup was a factory option
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2335 |
Posted: 13 Oct 2026 at 7:52pm |
I have or should say had one "rocker pedal" type on an I600....
I removed it and installed an original big stick in its place. It was near impossible to adjust the power divider as the tractor had to be running to have hydraulic pressure from Power steering unit to switch from foward to reverse. I still have all the parts if someone is interested... |
elec
Posted: 15 Oct 2026 at 11:18am |
I was thinking about removing the foot pedal and putting an electric actuator on forward reverser for push button shuttle on joystick. Anybody ever heard of anyone doing this? Do you think it will work?
Posted: 15 Oct 2026 at 11:25am |
No. Too slow reacting.
