d15 series ii three point on series i d17
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: d15 series ii three point on series i d17
    Posted: 03 Oct 2025 at 1:24pm
i have a d15 17278 sn at the shop to re pack some loader cylinders and was looking at the factory three point hitch  has any one tryed putting that setup on the d17
Edited by HudCo - 03 Oct 2025 at 1:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 2:51pm
Some things to consider: #1. A 4500 lb D-15 series 2 can destroy one of those category 1 hitches if used heavily. How long would it last on a 5500 lb D-17 ??   #2. I think the torsion bar and draft arms would bolt right on, but how do you intend to get the splined lift arms off the splined shaft??  You could remove the lift arm housing and remove both shafts with the lift arm still attached, I guess. It would mean removing the lift arm housing on both tractors to get it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 9:09pm
The D10,D12 and D15 3 point hitches were too light!The mounting bolts were placed incorrectly. JMHO, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 42 minutes ago at 11:00am
Dad pulled a heavy Oliver 3 bottom plow with his series II D15 for over 30 years and never had issues with the 3 point lift. Staying within the limits of the 46hp tractor or any tractor for that matter, is key to not overloading it causing breakage. Working outside of its designed load is asking for problems. Dad’s D15 sees a lot of 3 point work till this day on our farm, mainly sickle mower and blade work. Other than the garden it hasn’t plowed for 20 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 9 minutes ago at 5:33pm
AC720Man, only one in existence then, my apologies! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 4 minutes ago at 7:38pm
I guess we should feel lucky, but again we don’t abuse our equipment. No hurt feelings here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 34 minutes ago at 8:08pm
We don't abuse equipment ever! They were a piss poor design from the get go. Crawl under one and study the mounting holes, you will see what I mean! Tracy
