D15 series 1 steering u joints |
dale melenia
Topic: D15 series 1 steering u jointsPosted: 21 Mar 2023 at 6:36pm |
How does the steering linkage come apart to replace the mid u joint? This is a D15 diesel series 1.
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 22 Mar 2023 at 11:31am |
If I remember right, the lower shaft slides forward in the splined coupling at the gearbox. you then grind of the peened over pins and drive them out to get the yokes off.
I did this on my dads D17 years ago, and when I did it I bought the 2 yokes and ujoint together from Brenda at Sandy Lake cheaper than AGCO wanted for just the ujoint |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
dale melenia
Posted: 22 Mar 2023 at 7:39pm |
I will take a closer look at that. Thanks for the information.
Posted: 22 Mar 2023 at 8:04pm |
Hammer out both Ujoint yoke pins. This takes 3 or 4 lb hammer, a proper sized punch and grind off the pins end flush with the yoke. With the engine off, turn the steering wheel hard both ways and break one shaft loose inside of its yoke. Re-install that pin and continue turning the wheel until the other yoke breaks free. Lots of penetrating oil and maybe things will slide apart.
Edited by DrAllis - 22 Mar 2023 at 8:19pm |
