D15 Brakes
WeisAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Topic: D15 Brakes
    Posted: 31 Dec 2015 at 4:56pm
Hey Guys,
  I'm starting on a new chapter with this D15 and finally doing the brakes.  Looking for advice/opinions on all the things I need to correct and replace.  I'm planning on having Rick replace the shoes and possibly having the drums replaced or turned.
  Interestingly, the left brake has never worked.  I assumed that the pads were completely worn or something was broken.  Surprisingly once getting in there everything appears to be in good shape.  Maybe the pedal wasn't adjusted correctly.  Any thoughts?
  Also, is there a big difference between the WD/WD 45 brake vs. a D15 brake.  I was dreading having to pull the infamous pivot pin but one just pulled out with my fingers.  The left one appears to be in pretty good shape.  Am I missing something with this???
Left Brake Pads
Edited by WeisAC - 31 Dec 2015 at 4:57pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 5:48pm
WD45 brakes are completely different from a D15, you have no worries here - no pivot pin to deal with.  As you see, the D15 brakes are very simple and straight forward.  Can't explain why the left one was not working.  Make sure you have the lever set up right before you slide the axle back in.  Also replace your axle seals prior to reassembly.
TractorTechLuke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TractorTechLuke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2015 at 8:14pm
Last year about this time I did the brakes on my d15. There's not a whole lot to d15 brakes. Relign your "pads" as I call them, possibly replace your drums or turn them, and most importantly replace your seals! I couldn't get the thick seal like came in these tractor so I replaced them with two of the modern thinner ones and it works great! There was a few pieces where the linkage actually moves the actuator that were wore from years of use and while we had it apart we built theses pieces up with weld and ground them back like new. It's a fairly fun project that I enjoyed! Good Luck!
-Luke
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 8:50am
I helped with this brake job . The shoes really don't look that bad and the drums don't have much of a ridge on them . We also didn't see anything that looked broken or excessively worn . Maybe when it's all cleaned we'll find something . Beginning to think they've never been adjusted . Also wonder if we'd gain anything by replacing the drums ? THANKS for any advice or thoughts .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 9:13am
Is it just my bad eyes or do the 1st pictuures look oily to anyone else? I know when the seal goes, oil weeps onto the shoes and drum and stuff. That will account for 'no brake' symptom. I have 3 to do..one day....maybe this year ......
Have to ask , is the rear end oil level OK or HIGH ? If high it's a sign the ram seal for the rockshaft is leaking. I drained 8 gallons out where 3 should have been...
Jay
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 10:16am
The brakes in the top picture look oily to me as well. Rick
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:52am
I've done lots of work on D17 tractors.  Have never touched a D15, 14, 12 or 10.  Just surprised to see that the brakes on a smaller D Series are pretty much the same as on my G.  I've redone the brakes on my G.  They stop the tractor but don't hold like the bigger tractors do.  Of course on the G, the brakes are right on the axle.  Probably hold a little better when the brake has the mechanical of the final drive between it and the wheel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 11:53am
Thanks for all the advice guys.  I'm planning on replacing the seals, drums, shoes  as recommended.
 The left side shoes  were a little oily.  If you look closely the right lower stud is actually a bolt.  This lead to some leaking issues on that final drive in general.  Gonna add that to my list of things to fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 1:38pm
Is the oil seal that you guys are referring to the differential carrier oil seal?  Just behind this plate...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 1:44pm
yup..... I have 6 in front of me, National # 471765, that I have to install 'one day'. They are narrower than originals,so hopefully I can put 2 in.
Others may know of alternate part numbers for seals..
Course if you need practice, you could come on up to snowy,cold Ontario....hehehe
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2016 at 1:53pm
Might take you up on that Jay just for the snow.  We rarely get any in South Carolina!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TractorTechLuke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 9:28am
When I did my d15 I replaced the seals and shoes but left the old drums. Brakes work good now. One recommendation if you use your old drums is if there is any lip left on the edge of the drum where it didn't wear to take a die grinder and grind the lip down or you take a chance of cracking your shoes when installing. The only problem we ran into with the old drums was they were wore enough that once we slid the housing back on we had about 3-8 play before the brakes locked into the drums from the wear so we took it back off and welded those worn actuators pieces and now we have lots of adjustment room for the future.
-Luke
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 4:00pm
Probably boring to most of you guys but I wanted to show how I got the drums out.  If any of you are like me you like to see pictures to give you ideas on your project.  Left side came easy but right side was difficult and required repeating heating and penetrating oil.  Coming your way Rick!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 4:10pm
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 4:20pm
Thanks for posting all the pictures!!! I have the same job coming up on both of my D14's...now I know much better what to expect. Seeing your pictures in color gives me more motivation to do the job than looking in a repair manual with black & white pics...LOL
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 4:43pm
I did a brake job on an industrial and it had metallic blocks instead of linings. All the rest was same as D/14.Greese on my D/14 almost got me killed , ran down a mountain side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 8:13pm
Good job !! Guess my puller finally made the big time .
Jeff K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 9:01pm
I just replaced the shoes on my D10 with the new ones from Rick in MO. He will send you a great product and please like everyone else said "replace your seals".
It's doubtful that you will have to replace the drums. If they are smooth, they are good.
You must clean out all the oil/sludge everywhere including on the outside of the drums. You can use a thin putty knife and strips of a torn up bath towel to get it very clean without pulling the drums..
Jeff
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 10:34pm
The brake shoes are still usable. Just burn the oil off of them with a propane torch and they will look like new. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 6:46am
Thanks for posting the pictures, I don't own a D15 and so far have never been asked to do a brake job on one but still interesting to see all the pic's.    Nice to know we have a good source for linings in Rick to go to for these projects!!!     Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 11:54am
Uh oh . Somebody forgot to put the platform u-bolt in before they put the new drum in . We had to remove the drum and now have one side assembled correctly , I hope . You can see said u-bolt in the pics above . By the time we get the old D15 back together we'll have all this stuff figured out .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 4:25am
Here's an old post of our Series 1 D 15 brake job that may help Tim
Good luck
Edited by ACinSC - 17 Dec 2025 at 4:27am
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 8:34am
Thanks for reposting that. I did get some info from the replies.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 8:43am
Glad to help Hope the pictures came up for you. They did on my phone. Good luck
Edited by ACinSC - 17 Dec 2025 at 8:58am
