d-14 voltage regulater |
tractorboy
Joined: 03 Oct 2009 Location: southern Va Points: 480 |
Topic: d-14 voltage regulaterPosted: 25 Apr 2020 at 3:10pm |
I took the mounting bolts out to move the voltage regulator to access the starter last week . I got starter rebuilt & put back in now it wont charge at all [Batt reading 12.54 volts while running]I seem to have slight stray voltage on the mounting tabs which I don't understand since they appear to be isolated in rubber. I didn't remove any wires going to the regulater & they are all tight. maybe it needs to be"'flashed" , but I 'm not sure how to do this since this tractor is still very original, POSITIVE GROUND. thanks, keith so va
Alvin M
Posted: 25 Apr 2020 at 3:51pm |
Regulator Must Be Grounded To Work
tractorboy
Posted: 25 Apr 2020 at 4:14pm |
By "grounded" do you mean the mounting tabs??
Alvin M
Posted: 25 Apr 2020 at 4:35pm |
Yes It Also Has A Wire From Reg To Mt Taps Make Sure That It Sill There
tractorboy
Posted: 25 Apr 2020 at 4:48pm |
ok thanks !
