D12 steeing box rebuilt kit question
Garthster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Topic: D12 steeing box rebuilt kit question
    Posted: 21 Nov 2022 at 6:58pm
Hello all, just got to wvaluating the steering box on my d12. The main buchings are ok, but all the bearings and seals are smoked.
I wasnt able to find a rebuild kit. What are you guys doing to for seals and bearings on these units?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 7:20pm
I'd take the bearings to a good qualoty local auto parts store, find the oldest guy there, and ask him to take a stab at cross referencing them.  Should be some numbers on the bearings...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 7:32pm
IF you get the ID and OD of seal or bearing, they can be cross referenced or looked up on internet.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 7:48pm
Hey Steve
Could you give us a 'Training Video' on how you measure a Brg.
I for one would be very interested.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 7:54pm
You need the ID, the OD and the width... then you need to know if you want a ball bearing or a roller bearing......... Here is a drawing.... movie a the bottom..
lets say you measure the ID (d) to be .560" and the OD (D) to be 1.180 inch.... then i search for "bearing .560 ID"  ......... or "bearing 1.180 OD"........ note that a LOT of bearings are measured in mm ... a common lawn mower spindle bearing is .669 inch which is actually 17 mm ........ so sometimes if you measure .665 or .670 ... you might want to search for "17 mm" .
Edited by steve(ill) - 21 Nov 2022 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 8:04pm
90% of all bearings are METRIC.. If your caliper reads in inches then multiply by 25.4 and you will convert to mm.... Example ............ .669 inch x 25.4 = 16.99 mm  ... so that is a 17 mm bearing..
If i type in "17 mm ID bearing" on e-bay, i get several options for the OD and WIDTH... this is one.. if i look at the OLD race, i might see the number "6203" on the race... if the bearing is damaged, you go by the dimensions... 17 mm ID... 40 mm OD... 12 mm Wide. ..... a 17 mm bearing ID could have several options for the OD... 40 , 44 , 52 mm OD ...... so you have to look close ............ seals work the same way.
Edited by steve(ill) - 21 Nov 2022 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 11:15am
The bearings in a D10/12 box are a bunch of balls caged in a plastic retainer, much like Ross B & C boxes.  Most likely NLA from anywhere. I have just added another ball.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 7:57pm
Do you have part numbers or pictures of what your looking for.
This page was generated in 0.108 seconds.
