D12 pull a tiller?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D12 pull a tiller?
    Posted: 14 Sep 2023 at 7:32pm
Will a D12 pull a 5 foot tiller well. Have any of you guys done it? Thanks, Tracy
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 9:11pm
I run a 6' Kabota tiller with my D10.
No problem.
I love the D10/D12 PTO
wish all the D series had that feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 4:38am
If your 10/12 has it, a HiLo really helps with a tiller.  Sometimes 1st isn't slow enough...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 1:04pm
Mine at present doesn't have high - low. Wanted one narrow enough to make a raised bed hiller. Thanks, Tracy
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 3:42pm
I owuld be worried about the tractor going slow enough, most of these old tractors have a pretty fast 1st gear high and tiller do better pulled slow. Of course I don't have a D12 or a tiller. You might not know until you try it
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 4:53pm
Definitely would not be my first choice
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 5:19pm
A few years ago I bought a 720 with a loader on it, it has a 3 point. It also came with a 3 point Roto-Tiller, with, I was told new engine on it. If any of you wood like it, make an offer. I've never used it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 11:29pm
my D10 III has hi/low...
Would not recommend running one without hi/low...
no problem with power just gotta go slow.
OAN: i dont believe D12 Would cover 5' foot print. Unless you like tracks on your tilled ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 11:06pm
Benny, I want to use it to hill up raised beds. Not worried about the tire tracks between the beds. They get covered with weed barrier . Thanks, Tracy
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:45am
what type a soil ?
Probably fall is best
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:02pm
I make at least 2 tilling passes in opposite directions.
The 1st pass is at 1/2 throttle, and the final pass in the opposite direction at full throttle!
It is much easier on the equipment and hopefully do not find anything left buried in the ground!
The CA can handle the 4 ft tiller fine!
Tire tracks are to the outside and not a problem!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 10:45pm
That looks great!Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 4:47am
CA is most underated tractor.
Great power !!!
for its size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 6:02am
I have a 5' on my D-14, offset to cover the right rear , works great though I have to feather the 'big stick' for 1st passes. You need to go slooooow with a tiller as others have said. Adding lots of compost will really help. I'd till N,S,E,W to mix everything really well and 'level' the land.
One option is how you setup the garden. If you use a 4' or 5' , with 'no offset', the tire tracks become the pathways to get TO the weeds, er, veggies ! You really do not lose any 'garden growing' area,minimal weeds in the paths and beds are clearly marked out.
Did this for years.
