D12 fuel gauge float and gasket questions
ShellJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShellJ Quote  Post ReplyReply Direct Link To This Post Topic: D12 fuel gauge float and gasket questions
    Posted: 23 Nov 2021 at 8:03pm
I was able to retrieve the original cork float that was loose in the tank (so that's why my fuel gauge doesn't work, hmmm). Been shopping online for a replacement float and looking for info on how to attach the new float. Seems people get pretty creative with substituting floats from used auto pumps. But if I order a new float specifically for the D12, does it come with whatever I need to attach it? I see there are indents in the rod, above and below where the cork was originally attached. But no remnants of whatever the original hardware was that fit in those indents. How to attach the new float?
Next, the rubber gasket for the gauge is hard and cracked. I read where people had trouble getting a replacement that would actually seal well. Can anybody point me in the direction of where to order a gasket that works?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2021 at 10:06pm
I used a non sinkable float from a car, kind of flatted oval shape. It is slide onto shaft up against a washer and flat spot, then a washer behind, rod flattened behind washer to hold it on. Gasket is available thru AGCO and several other sources. HTH Tracy
Gatz in NE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2021 at 10:42pm
here's a thread on gauge floats;
https://www.allischalmers.com/forum/d17-gas-gauge-float_topic116387.html
OR, a Model A float ; Ford #A-9313-C works very well.
It's what I used on my D17sIV
A bit of modifying is in order, but it can be done with ordinary tools and a drill.
IIRC, the open end is swedged to retain the float.  Just have to use a small hammer and "re-round" it, then file it down smooth 'til you can remove the float.
Drill a small hole for a brass cotter key in the same area to keep the new float on;
used 2) brass washers , one on either side of the new float.
If you don't like buying Chinese, buy from Norm as in the thread above.
For a gasket, I'd get some stock gasket material from an auto supply and cut one to fit.
Apply a thin coat of Permatex #2 to both sides of the gasket. Trim if needed.
Permatex #2 is the non-hardening type.
Edited by Gatz in NE - 23 Nov 2021 at 10:49pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 6:22am
I had the same issue on my D17 this summer. The movable gauge parts were pretty wore, so I bought new. The new gauge doesn't read correctly. 1/8-1/4 on the gauge is empty. I ran out of gas a couple weeks ago...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:00am
I've just used a sediment bowl gasket for the gauge. There are a couple different sizes and I don't remember which one fit, although it is just a standard size, nothing special.
JLS retired View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLS retired Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 10:15am
sometimes you have to bend the wire arm just a little bit to make a guage read correctly when you replace parts, good luck, usually takes a couple of tries!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 10:22am
That's a brilliant idea! I don't know why I didn't think of that!!
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 11:17am
we sell the floats and the gaskets. djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShellJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 12:13pm
Great pictures! I have small copper washers and steel Cotter pins on hand. But I'll try to find brass if that's going to hold up better.
As I mentioned, my float had already fallen off the rod and there are no washers left, must have disentegrated over the years. I will take a closer look at the rod. Seems like it just had flat spots, indentations, not flared out beyond the round shape (if that makes sense). Maybe the flare is so minimal that it's not obvious.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 5:23pm
no reason for brass….just what I had on hand at the time
