D Grader Voltage Regulator
Pgriswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Topic: D Grader Voltage Regulator
    Posted: 25 May 2026 at 2:19pm
Hello All
Just rebuilt a D grader and want to make sure we wire the alternator and voltage regulator correctly. The alternator is a 2 pin with F and S. The Voltage regulator has Gen on top, F, Batt, L on the bottom. Could someone let me know there to connect .
Thanks
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 3:53pm
Is this an existing alternator/regulator combination that previously worked together or are they new components?
I ask because the markings on your regulator seem to indicate that it may be for a generator rather than an alternator. They need to be matched correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 4:00pm
Hello Les
Yep new components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 4:07pm
F and S stand for FIELD and SENSOR... normally that means you have an INTERNAL VOLTAGE REGULATOR.... I assume this is a DELCO 10 SI alternator ?? ...... who told you that you needed an external voltage regulator ??
your 4 terminal voltage regulator sounds like a GENERATOR regulator ?
something like this.... if you have a diesel, forget the coil and plug part..
Edited by steve(ill) - 25 May 2026 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 4:49pm
Hello Steve
Original set up had a voltage regulator so assumption was I needed one. Wiring was a mess and not even sure the regulator was hooked up.   I think what you have is what needs to be done. I do have a 10si alternator.
Thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 5:49pm
i use the 10 ohm 10 watt resistor in the sensing line.. Some people use a DIODE and others use an IDIOT LIGHT on the dash...... I got the resistor idea from a Service Bulletin in 1975 DELCO manual on how to bench test the alternator..
your original voltage regulator was probably for the original GENERATOR... and was abandon in place when the new Alternator was installed...
Edited by steve(ill) - 25 May 2026 at 5:50pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 6:38pm
The 10DN alternator with an external regulator was commonly used as the step from generator with regulator to alternators.  I agree his regulator terminal designations appear to be a generator regulator.
The drawing posted for a 10SI is wired correctly; however, the labelling of the spade terminals is wrong.  The #1 spade (left) is the excitation terminal, not R (sensing feedback to the regulator).  The #2 (right spade) is the sensing terminal, Not F (field).
The Delco 10DN alternator used an external regulator.  The two terminals where the small wires plug in are labeled R (left spade) (controls the regulator's turning an indicator light off when the alternator is charging) and F (right spade) for field excitation.  These spade terminals are in the opposite locations from a 10SI's spade terminals.
Edited by Jim.ME - 25 May 2026 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 6:55pm
youir right Jim... i have missed that for several years... the wires are RIGHT and the NUMBERS are right... but the R and F label are reversed !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 7:07pm
Thank you guys for making this easier. Appreciate yall
