Critters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Critters
    Posted: 25 Jul 2025 at 1:44am
Sumpin Weird going on.  For the last couple years have had Coons on the House Deck(three at One Time, Momma and two cubs), Skunks attempting to nest under the walk to the Front Porch, TWICE now. Then yesterday as was washing hands for dinner look out front window, a Ground Hog sitting just feet off the front walk, acting as if Owned the Place, munching on sumpin staring out across the lawn and as opened front door startled it, arched its back, high pitch growl and darted back to a burrow, AGAIN, Under the Front Walk.  Will be excised and forced out tonight when have plenty of 'Deal With' time of the weekend.
Why Now?  Why after home has been here for several years have these decided 'Nice Place to take Residence'?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:07am
Becoming more accustomed to people being around and therefore less cautious of being closer plus fewer predators close to the house.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:34pm
They're moving in because they smell the history of OTHER burrowing wildlife in that area.  EVERYTHING leaves a scent... Mice and rats leave a trail of urine that other rats and mice follow... so raccoons, skunks, oppossums, and groundhogs are no different. They even know the cent of humanity, and follow it to find our refuse containers, garden plots, and fruit trees.  A raccoon knows the scent of sweetcorn, and will follow it in for miles in any direction to hit your rows.
Groundhogs... only out in the middle of the day, when sunshine is directly overhead.  Y'know the 'Groundhog sees his shadow' bit?  There's actually a little bit of reality to this- groundhogs' eyesight is very poor at distances, and their primary predators are either fast-moving, very large coyotes, or raptors- avian predators... eagles, hawks, owls...
They hear and feel coyotes and other ground-running predators, but their only warning of birds of prey are the shadows coming towards them... so they avoid times of day when it's very overcast, or their shadow is far to the side.
canteloupe... a couple pieces in the yard, and one in a live trap, but tie it in with wire, all the way back... they'll usually follow them right in.  IF you have a good vantagepoint from inside, however, a zap from 22mag is a good choice.
Edited by DaveKamp - 25 Jul 2025 at 10:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:40pm
i spray the yard for BUGS and WEEDS twice a year.... Killing all the BUGS gets rid of the food for moles and others... Snakes dont like the weed killer on their belly....  Coons only come around if there is dog or cat food out to eat..... 22 takes care of them..Never seen a skunk around here... ground hogs normally stay few hundred feet from civilization / house.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 4:05am
Bought Two CTL traps, already baited and waiting.  .22 with hollow points is awaiting the final journey send offs.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 8:27am
Something was taking the black plastic bait boxes that I put mouse,rodent poison in . I started weighing them down with large rocks chains, large pieces of wood. Still would pull them loose and drag down in the woods 50 60 yards from the house. Set out a #2 leg trap to see what was causing. Large ground hog . 22 buckmark did the job .
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 4:36pm
MICE - overran with them around house and over the winter inside , put out mouse blocks and have went through 8 pound bucket in a week . Took 2 pound plastic coffee cans and ran 2 pole barn spikes up through bottom to set blocks onto inside and pup pea gravel into them to weigh them down - 4 blocks in 2 days in each of 3 of those I have out . Drilled 7/8" hole in 3 spots in sides of plastic .
 Seems bird feeders have drawn them into back yard so either feeders for birds go or have to find another solution .
 Was watching you tube where they say jiffy corn bread mix mixed 1 part mix and 2 parts baking soda will do them in - NEXT to try as the dang mouse blocks (TOM KAT) are expensive for snack food for mice .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Clay View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 5:11pm
Here at the "Story Cat Ranch and Home for Wayward Cows, we have no rodent problems.  Just enough cat food to keep the cats around but not too much. A hungry cat will earn its keep.
I tell my cats....If I find evidence of mice or rats in the barns or around the grain bins, they WILL BE REPLACED.  So far, the cats understand their job description.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 4:30am
We had two baby coons show up last spring. They must have lost their momma .
I kept them fed and over the winter they never came around except on rare occasions on nice days.
They both showed up this spring with young’ens of their own.
They’re becoming a nuisance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 6:42am
Almost like welfare queens!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 3:13pm
Back when wife was alive and started feeding stray cats it was just one or two , then got up to 17 or so kept showing up ,
As she could barley get around house I would find her outside in winter feeding cats , so had to take over that job - now no mice but cat food got expensive and as she was having vision problems with cataracts I started buying small size dog food in 50 pound bags .
 Lot cheaper than cat food back then at Sam's club . Worked until she had eye surgery and had to go back to cat food .
  When she passed I was still feeding cats but numbers started going down be it coyotes , owls or something else but got down to 3 then those didn't show up but found 3 kittens out under some boxes in back - Sons GF found homes for them .
 Now have one cat wander by every so often but dog thinks it's a chase toy so it doesn't come around much .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 7:21pm
exactly what their like.
