crankshaft casting number???
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Topic: crankshaft casting number???
    Posted: 29 Apr 2010 at 6:19pm
Anyone with some insight please. I have a wd45 block with a crankshaft casting number of 226231-L. I believe it is a 4.5" stroke but I have atleast .5" distance at TDC before the piston would be at max stroke of the cylinder. Thats also with an A&I Products flattop piston.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 6:54pm
that sounds right. whats the question?
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:19pm
If its a 4" stroke or 4.5" stroke by telling the distance of the piston traveling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:24pm
the number on the crank is 226 that pretty much tells its a 4.5 stoke crank . but yes you can measure the pistons travel to . If you have a 4.5 stroke 4 inch bore and youre flat top piston is just 1/2 inch below deck at tdc . you will have a 9.2.1 comp. ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:27pm
The 226 in the part numbers probably denotes a 226 cu in which would be  a 4.5 stroke crank. The 4 in stroke engine was a 201cu in. The head is flat so there has to be some space left at the top of the stoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:27pm
I have 4.125 flat top pistons. what would that ratio be about. See I got this wd45 from my grandfather and have the engine together but  I always enjoy learning new info. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:32pm
If its trully 1/2 inch down from the top of the deck at tdc with a 4.125 bore .042 figured for gasket crush 4.25 gasket bore with a 4.5 stroke ,flat top  piston with no valve reliefs the cr would be 9.26.1
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 7:49pm
Edited by CTuckerNWIL - 29 Apr 2010 at 7:49pm
This page was generated in 0.075 seconds.
