Crank pulley Problems
hamman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 8:43am
I was lucky to get a motor with the ring gear on the fly wheel. I don't have a starter at this time so I do need to be able to turn the motor over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 11:06am
I haven't been able to get the bolt out. Cut it square and tried sockets. Just stripped. We cut a nice slot in it and it just stripped out.  Now a question. Is there a key under this bolt or is there an indent in the crank end where the bolt is tapered and fits into?  My next try is to cut the bolt flush with the pulley and try to drill it out. I don't want to screw up the crank by drilling into it. Thanks.
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 11:58am
If It were me, I'd torch the backside of the pully and leave the bolt. You only need to melt the metal behind the bolt. If it is threaded instead of indented, because at this point you can't be 100% sure how they've fixed it. Once you torch loosen the pully the bolt will either fall off with it or you will have enough threads for the visegrips.
This does require a bit of knowledge and skill with the torch as you must not get the crank over heated(damaged).  But since the pully is junk it does not matter how you treat it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 1:02pm
It should have a tapered hole in crank.The taper bolts/setscrews all over the tractor have same taper.Starter lock,brake/clutch cross shaft,steering arms on wide fronts etc.
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 1:56pm
    If you haven't already, I would take a hammer and punch, and use it on the center of that bolt, just in case it is an allen head full of crud and then painted over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 2:57pm
It was a bolt with the head broken off! I have drilled it out toi where there is just a 1/4" on one side holding on one side. I have drilled hammered and punched with no results. I am afraid to drill any further in fear of drilling into the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 4:48pm
So now is the time to get the welder out. Find a washer that will set centered over the bolt without hitting the back of the pulley. Weld the washer to the bolt thru the center hole. Lay a nut on the washer and weld it to the washer, this doesn't have to be perfectly centered or even level or square with the bolt. Put a wrench on the nut and back the bolt out. It's really pretty easy to do using a washer first. I have seen a GOOD welder reach thru a 3/8 inch nut and weld it to a bolt, but that takes a bit more skill to do.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 5:30pm
I think you would know when you hit the crank with the drill bit, it should be a lot harder than the bolt. Even if you do hit the crank I doubt you would damage it enough to matter since that part is just for the set screw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:04pm
I drilled the bolt out but due to the odd angle of it I drilled off center of the bolt wobbling out the pulley. The pully being drilled is not a problem as it is junk anyway.  I have about 1/2 of the bolt left in an arc. I will try to post a picture in a while. I have drilled as deep as I am going to. I am afraid of messing up the crank. I thought of using a torch to blow out the rest of the bolt but I am not that good. I tried to get a nut started on the bolt before anything but that didn't work either.  We have to cover our plants due to frost comming tonight so I will post the pic later. Thanks. Roger
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:08pm
So keep drilling it bigger till the bolt is gone. That pulley would be a good one to face off the front and add tapped holes to bolt pump drive on but won't be much good if the set screw hole is whollered out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:11pm
BIL was just here and brought his nifty "Bolt Out" kit we gave him for Christmas a few years ago. To bad I messed it up already. His advice is to drill out more of the bolt and keep increasing the size as I did before. Hopefully I can get the rest of the bolt out with this method. If that wount work I think I am going to try to grind the pully off.  May take a while but I have lots of time. No pics camera broke. Thanks for the ideas. Roger
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 10:36pm
CAUTION  !!! crankshaft is not hard so don't think your bit will stop when hitting it. try to drill a small but as large as  possible hole opposite of your screw up hole and then take a small punch and gently tap the punch at the angle to unscrew what is left. btw tap it counterclockwise.  or drill two holes side by side on the remaining part of the bolt, take a small sharp chisel and open up a screwdriver slot and take a small impact wrench with a screwdriver bit and drive it into the slot as deep as you can and set it to barely hammer and turn the bolt out.  next time weld the washer and nut on.  looks like you had plenty there to do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 1:49pm
I am just about at my wits end. I have drilled and tried to break out the rest of the bolt to no avail. I hate the thought of hammering against that pulley to break it because of the crank, bearings, seals etc.. I just don't know how to get that thing off now. It has set me back qite a bit for getting it running and out and about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 2:39pm
sent you a pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 4:33pm
 You past up the best advice on here by not welding a washer to the bolt and then welding a nut to the washer and backing the whole works out.
 Now , it sounds like the safest thing you can do is start grinding on the area where the set screw is. If you grind the hub and left over set screw all the way down to the shaft, the pulley will come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 6:22pm
ctucker you sir are correct. I  have done this sort of thing before but with better results. If i could do this over again I certainly would. I believe I will start the grinding process tomorrow and get it done. Thanks. I will let you all know how it goes. Roger
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:10am
Not much progress on the pulley. New roof on house and Dr. appts. have kept me away from the garage. With the temp being in the 90s + that hasn't helped either. Hoping that after Saturday I can get back on it. I have been plotting a course of action to get the pulley off. I have tried to think of a way to save it but that hasn't happened yet. I believe if I use a 6" angle grinder with a thin cutting wheel and cut on both sides of the pulley and then use a sharp chisel striking it sharply should make it crack and come apart from around the crank. ( Thats what I dreamed in my perfect dream)
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 8:59pm
Finally got the pully off tonight. My BIL who is a mechanic came over and with my Porter Cable and Milwaukee Sawzalls cut a slot in the top of the pulley enough to drive a chisel down into it and darned if he didn't split that pulley in half. As I had said before I had drilled as far as I could. After getting the pulley off I can see where I had drilled into the cranl. It appears though that it did not hurt the hole for the bolt enought to worry about it. I do see a lot of shavings and saw (cast) dust in the hole in the crank. I am going to use a small powerful vaccum to suck the shavings and dust out. I am afraid if I used air it would push it into the crank and possibly out into the bearings. I will try to post some pics of the finished product. Thanks for all you help and if you have any other suggestions for me feel free to say so. thanks again.
