couple G questions |
CTuckerNWIL
Topic: couple G questionsPosted: 12 Apr 2010 at 7:44pm |
Is there a place for a temperature gauge? Is the governor supposed to be set up similar to the other models? IE 1/16 inch pressure on idle screw when shut down. My, oops Liz's G looks like it might have too much water and it starts to blow out the overflow after about 5 minutes of running. The governor doesn't.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4802 |
Posted: 12 Apr 2010 at 8:16pm |
Niether of my G's have a temp. gauge and I can't help with the governor.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 12 Apr 2010 at 8:29pm |
if you are filling the radiator to the top, it will blow off as thewater expads as itr heats. it is normal for the level to be below full after it has been run. The G doesn't have a gauge or a water pump, so it will tend to run on the hot side. It uses hydro-syphen to cool it. Bob
CTuckerNWIL
Posted: 12 Apr 2010 at 8:36pm |
Ok thanks guys. Now if I can get the little flathead to govern like an Allis, I'd be tickled pink.
CTuckerNWIL
Posted: 12 Apr 2010 at 8:49pm |
The rad was full to the top when I bought the tractor. I thought that might be all that was wrong but I suppose it wouldn't hurt to back flush the thing for a while.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4900 |
Posted: 12 Apr 2010 at 9:03pm |
Charlie, just be sure there's enough water to cover the top neck. the water must be able to make the loop or she's soon to be dead. Check your e-mail in a moment, some reading material (manuals) on the way on the G
Joe |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
CTuckerNWIL
Posted: 13 Apr 2010 at 1:31am |
Thanks Joe. Your the best.
