Correct batteries for a 190
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Topic: Correct batteries for a 190
    Posted: 23 May 2012 at 11:46am
Can someone tell me what the correct size batteries are for a 190xt. My battery box currently has 2 car batteries with a bunch of wooden shims holding them tight. Thanks
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 2:29pm
That works and the car batteries can be bought with 5 or 6 year warranty where tractor battery has at most 2 year and will cost more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 7:27pm
I believe they are supposed to have 2 , 900 cca hooked on parelel
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:34pm
i put two 1200cca in mine
    Shawn
190XT,D17and 7045
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:51pm
Should be group 31.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 10:10pm
I use group 27
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 6:31am
27 is standard and 31 were the heavy duty option if I remember right. I use 27. Either will work.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 6:36am
Thanks guys. I know that the car batteries will work too, I'm just kind of anal I guess. Just don't really like wooden shims and bungee cords holding my batteries down. Especially when the original hold down is there and in good shape.
Andy190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy190xt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 2:21pm
I can see that this thread is quite old but I was just wondering what size wire to run for the batteries? I am glad of any help
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 2:35pm
Welding cables, Andy. Welding cables have a little bit smaller cross section than SEA wire sized cables, but they are more flexible.  They work well.  Have a truck repair shop build a set for you.
Edited by DougS - 13 Nov 2017 at 2:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 5:49pm
I have 2 car batteries in mine. with wood between/under them. seem to last as long or longer than tractor batteries. and are cheaper
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 8:13pm
Group 31 from TSC, they are made by Exide battery co for TSC. $99 each. Do a great job so far but I have only had them a year.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 8:28pm
The old ALLIS CHALMERS  part # was 243473 or BCI group size 30H for a 190XTD.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 9:10pm
I have had Interstate batteries in my 180 diesel for years.   Interstate just seem to do much better than other batteries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 8:01am
Looked at Exide recently at a large chain "Farm & Ranch Store". Asked someone I knew had been at that store for some time how many came back? Was told they were under review and that chain was looking at going with other vendors due to failures/returns before hitting end of warranty.
I stayed with Continental as the last one was ten years old. They change-up designs/ratings constantly on batts it seems and many of the low end now seem to struggle with lasting the advertised warranty period.
Subject to use and maintenance but Continentals have worked for me so far . . . .
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 8:48am
Can you fit 2 truck batteries in there. They do a great job and are usually much cheaper than the automotive ones. Would have to check if the top stud arrangement works for you.
This page was generated in 0.146 seconds.
