converting R style head to fit L2 |
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Topic: converting R style head to fit L2Posted: 30 Nov 2011 at 5:08pm |
I've found a 20' flex head close but it's off an R series combine. I have and L2. Has anyone on here converted one. I know it's been done before. I was just wondering what all had to be done. I know the R style was off set, will it still be off set once converted?
thanks in advance Derek |
Adam Stratton
Posted: 30 Nov 2011 at 9:09pm |
I went through that thought process not long ago. After a lot of measuring and figuring, I finally gave up the idea. The thing that I wasnt able to figure out how to overcome is the height. The width can be dealt with fairly easily, the hook-ups, wiring, and plumbing can be adapted, but the height of the hole, (and most of the back of the header if I remember right) is something like 8" shorter on the Rs than on the LMs. I figured if I went to the effort to make everything else fit, I would still probably have a mess with feeding. I might be wrong, but if I were you, I would start thinking about how to overcome that first, because the rest seems pretty straightforward. That being said, if you figure out how to do it, let me know! I have a nice 324 flex head for an N/R that I bought to try to put on an L2!
