compression WD
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: compression WD
    Posted: 21 Jul 2018 at 1:03pm
just out of curiosity, what should the compression be on a WD?
I think it is the lower compression ratio, it has the kerosene manifold on it.
I measure 40-45 PSI in all cylinders. It starts and runs fine
I am still confident of this;
Wait for the Lord;
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 9:21pm
Take out all four plugs shut off fuel and open throttle wide open and retest again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 8:56am
that was with all four plugs out and throttle wide open. im thinking maybe compression gauge goofy. doesn't matter, tractor is running fine, so I think I'll let sleeping dogs alone
Wait for the Lord;
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:17am
That seems very low in my opinion.  My scrap yard D17 gets 150 lbs.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 10:37am
A standard WD started life with 110#, a “low octane” WD with 80#.
Tractors run fine with less than they had new all the time, but if it is running good with good power, I would think that 40-45# is not accurate.
1951 B
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 11:48am
Lots of things can affect you he compression readings:
Altitude;
Ring wear;
Timing;
Valve lash;
Design of the pressure guage;
Cranking speed.
If every cylinder is the same, I wouldn’t overthink it.
You could also squirt a little oil in each cylinder and see if it goes up any.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 12:23pm
Good power is the key here. What does it do for heavy work? As stated above, squirt some oil into one of the cylinders while all plugs are removed and the throttle is wide open. Check the valve lash too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 1:25pm
That's what I was looking for. I knew a 'low octane' would be lower compression ratio. therefor lower compression readings, I just didn't know how low. I do suspect the readings I am getting are not accurate, but this is more an exercise in curiosity because as I said, the tractor readily starts and runs fine. As for power, I really don't know because this is my lift tractor, I only use it for picking stuff up, so as long as it can get itself around and run the hydraulics it passes muster
Wait for the Lord;
