Comments on Deutz-Allis NoTill 4 R Planter? |
Page 12> |
AllisUpstate
Joined: 06 May 2011 Location: Upstate NY Points: 1261 |
Topic: Comments on Deutz-Allis NoTill 4 R Planter?Posted: 10 Dec 2011 at 2:00pm |
I have been looking for a no-till planter for a while, and finally came across one only a few miles away. It is a Deutz-Allis (green) 4R. I couldn't find a model number off it, but it is an air planter, with dry fertilizer bins in decent shape, fluted coulters and double-coulter openers, hydraulic markers, etc. Plus it has a seed monitor, and was last used about 2 years ago then stored. So it seems almost ready to plant with just some basic cleanup and attention.
Anyone with experience on this model planter? I would be pulling it with a D17IV, which I assume should be fine in terms of hydraulics and power? Also, the air fans are run by the tractor electrics - would I have to switch the IV over to negative ground? Thanks in advance for any feedback or advice. |
Russ-neia
Posted: 10 Dec 2011 at 2:39pm |
This will get you started:
We've been using one for 20 years. Very good planter, but you must have at least 30 amps of power all the time. Series IV original generator was only 30 amp when new, and barely adequate. That will run the blowers, but no planting at night with lights. If I recall correctly, you need negative ground to operate the monitor.
The innovators offer what others will imitate.
AllisUpstate
Posted: 10 Dec 2011 at 2:52pm |
Russ-neia,
Yup -that's exactly like the one I looked at. 30 amps of power might be a problem. I was thinking about converting over to a single-wire alternator anyway, as they are available fairly cheap, and I can convert to negative ground as well. I forgot to ask the fellow, but perhaps you could tell me the adjustment range available for row widths? |
Russ-neia
Posted: 10 Dec 2011 at 3:57pm |
Row width can be taken down to 28" on the 4 row frame. They made the units so they could be spaced at 15" if necessary, but you can't do that where the lift wheels are.
What city are you near? Upstate covers a lot of territory!
AllisUpstate
Posted: 10 Dec 2011 at 4:02pm |
SE of Syracuse and NE of Binghamton and probably 1 1/2 hrs directly east of Ithaca.
Thanks again for the feedback on the planter. 30" rows will work just fine for us. |
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 10 Dec 2011 at 4:20pm |
Upstate, the model no. is 385. They are a tremendous planter, and will singulate seed up to 7.5-8 mph. I planted in drilled soybean stubble at that rate,and had as good a stand as the green or blue ones and better than IHC" There is stainless wear plates and plastic fillers,or bumpers, behind the seed plates that do wear, but easily replaced. This is about the only maintenance that I had other than maybe a chain wearing out. My advice is Buy it!!!!! I'm retired now, but wish I hadn't sold mine so I could plant my 5 acres of corn and maybe sweet corn.
AllisUpstate
Posted: 10 Dec 2011 at 4:42pm |
Dipstick,
Thanks! I'll go for it for sure, based on what everyone has said. The price is $750, but I can haul it home, and it seems to be in good to very good condition. |
Dipstick In
Posted: 10 Dec 2011 at 4:54pm |
Boy, for that price you would get a hel** ova planter, well worth working it over this winter before planting season. Wish I could find one here in Indiana for that price!
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8731 |
Posted: 10 Dec 2011 at 6:04pm |
I've heard enough good about them that I am kind of, sort looking for a 12 row 30 Deutz 385. would like it to have liquid fertilizer on it, and be somewhat close to north dakota. Darrel
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2336 |
Posted: 10 Dec 2011 at 6:33pm |
I have heard nothing but great reviews and praise about these 385 planters. If things get better, I would like to buy a small one someday myself!! Ryan
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 10 Dec 2011 at 8:49pm |
Don't buy it !!!!!!!!!! Neighbor has a 385 and wants us to plant corn for him with our JD 7000 since ours leaves a much better stand. The JD 7000 finger pick-ups are by far the best planter of there day you get what you pay for. We have planted alot of corn with our 7000's with minimal maintenance. If you want pickett fence stands get a Deere. Every company had weakpoints and planters was AC's and DA's. |
Ryan Renko
Posted: 10 Dec 2011 at 9:05pm |
Victoryallis, I'm not quite sure if your post is a joke or are you serious??? REALLY?? Ryan
MACK
Posted: 10 Dec 2011 at 9:50pm |
If a JD 7000 planter was painted orange you could not give it away. Next spring when corn comes up look at fields planted with JD 7000 and where AC 385 planted then see which has the most even spaceing. MACK
Dipstick In
Posted: 10 Dec 2011 at 10:13pm |
VictoryAllis, don't know how your neighbor takes care of his tools, but I never experienced that. And, I traded work with two friends with 7000's. I still was able to get back in the field before them after a rain!
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 10 Dec 2011 at 10:30pm |
VictoryAllis you are just telling a story of someone who doesnt know how to use there equipment. The fingerpickup works,you need to keep the speed down around 5 to get a good drop. I have never seen a 7000 that would drop as good as a 385. I have run them both. Finger pickup is nice you dont have any fans or vacs,just hook it up and go.
Upstate those motors will eat your alternator. I run a 385 for years behind our 185. When it was running in the field the amps were negetive. I would put an alternator on it just about every year.
IG
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 11 Dec 2011 at 1:47am |
a fella i knew was a JD man all the way...when the deutz-allis planters came out..i told him i'd heard nuthin but good about them....soooo....he talked the local dealer into letting him try one one spring...and in a few days....bought 2 8-row planters! they loved them!
David(Stockbridge)MI
Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Posted: 11 Dec 2011 at 6:07am |
Bought a 385 and planted with it this spring and it worked great. David
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
MI8050
Joined: 08 Oct 2009 Location: West Central MI Points: 226 |
Posted: 11 Dec 2011 at 7:00am |
Nick So. IN.
Posted: 11 Dec 2011 at 7:14am |
Darrel, last spring I saw a really good 12 row, with liquid fert sell for $500-$700 bucks (can't remember). I do remember they almost didn't get a bid though. The planter had about 1200 acres of planting on it.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 11 Dec 2011 at 7:23am |
One thing that I don't hear anybody addressing, isn't the D17 Series IV already negative ground. I thought all D17s were???
Still in use:
darrel in ND
Posted: 11 Dec 2011 at 9:39am |
Nick, that's the kind of deal I'm looking for!! For that money, I could even afford the freight to get er here to ND. Darrel
Moonlighter
Posted: 11 Dec 2011 at 12:19pm |
There is a 385 coming up on the purple wave auction
smithcarrie
Posted: 14 Dec 2011 at 3:44am |
comment on news google |
smithcarrie
Posted: 14 Dec 2011 at 3:48am |
Deutz-Allis NoTill 4 R Planter...I have been looking for a no-till planter for a while, and finally came across one only a few miles...And I'll find It..Share
you’re experienced for christmas
flowers germany for all my friend and
my family members..
Edited by smithcarrie - 14 Dec 2011 at 3:49am |
Lonn
Posted: 14 Dec 2011 at 5:47am |
reported
Wink I am a Russian Bot |
Lonn
Posted: 14 Dec 2011 at 5:52am |
We had a 7000 from new back in 1978. I should say the landlord had it and Dad bought it a dozen years later but we ran it from new. It was a real good planter but 5 mph was top speed. My old 330 Allis plants just as accurate if not more accurate as far as spacing goes and faster but lacks the easy adjustments of the 7000. Depth adjustment is a pain on the 330. I've always heard good things about the 385.
DougS
Posted: 14 Dec 2011 at 8:02am |
Switching to negative ground is no big deal. I don't recall what size wire runs from the generator, but I would make sure it is at least #10 if you install an alternator. Smaller wire can handle 30+ amps, but not continuously.
Kurzy
Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Posted: 14 Dec 2011 at 8:14am |
Howdy,
I have a AC 330 for sale, that is not a not till. Could you just put notil coulters on and get the job done? I thinking no-til planters are heavier from pics. Thanks Kurzy
victoryallis
Posted: 14 Dec 2011 at 11:01am |
We can get a nearly perfect picket fence stand with a 7000 planter especially with precision updates. Im my county almost all the planters are either Deere or Kinze with a couple CIH mixed in one white and the neighbors 385. I have a freind that bleeds CIH red but runs a 7200 JD and likes it. Allis made great tractors and combines but there planters can't hold a candle to Deere and Kinze. We planted alot of corn with a D17 and 4 row 38 Deere planter back in the day The cool thing about the finger pick Deere's is you can be planting soys or green beans or squash or sunflowers in a couple minutes of switch over time. I'm young and progessive enough not to play the color game sorry the Deere plant is a better move. |
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 769 |
Posted: 14 Dec 2011 at 11:29am |
I am an orange tractor guy but am with Victory on JD planters. I have no experience with AC planters but I have no reason to not use my JD 7000, I hear comments from folks about my corn spacing being so good. In my area seed corn is king and those guys still use alot of finger pick up planters, current models of course. And as mentioned earlier the parts availability is second to none.
Edited by Ben (MI) - 14 Dec 2011 at 11:30am |
Page 12> |
