Color sand or buffing
akmarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Topic: Color sand or buffing
    Posted: 29 Feb 2012 at 10:27am
Just painted a winter project.PPG omni paint.Would like to buff out and wax,Any suggestions on how to and materials?Thanks
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:52am
You should start with like a 1500 grit paper and work your way up to 3500 or 4000 grit.
When you are finished you will have to buff it out to bring the shine back. I use Meguiars, start with a heavy cut cleaner, finish with #9 swirl remover and top it off with a coat of there cleaner wax
1968 D15D,1962 D19D
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:57am
Don't wax for at least 90 days after painting.....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:58am
Thanks Don,Should I wet sand with these grits then go to buffer for finish wax?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:37pm
Yes, sand first to remove imperfections finishing with a 4000 grit paper.
The buffing wheel and rubbing compound will remove the scrates made by the paper
1968 D15D,1962 D19D
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 3:44pm
practice practice practice. you don't want to burn the edges. be careful.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 4:28pm
Have you considered just sanding and a couple more coats of color?   I myself  dislike the look of cut and buffed paint  compared to a well prepared and applied finish, plus most times its waaay less work to reshoot .  Be aware thet if you have dirt or runs or other surface defects,  they will eventually re- appear as a ghost after color/ clear sanding and buffing. Which omni system are you using ? And what are you working on ? car, truck, tractor?
 More information will get a more accurate repair strategy. And better results
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 8:26pm
I sprayed left over tractor paint mtk60080 a  mr186,mh168 on a car.Just a lot of small dust particles would like to buff out.
Thanks
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 10:43pm
Sounds like we're painting a Corvette, not a tractor. A tractor never had a paint job like your talking about. In fact, I don't think any of my cars did either. Spray it and let it dry, DONE. Bob
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 1:45am
With the proper compounds and buffing pads, finish sanding at 2000 is plenty fine enough. You need to be sure you have adequate paint coverage to start with, atleast 3 medium coats, imo. If you have no experience, extra care must be used around bodylines, crevices, etc....very easy to sand/buff through the high spots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:57am
Thanks for all the advice I post pics when done.
