Coil & Wires for Electronic Ignition
SmithCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmithCreek Quote  Post ReplyReply Direct Link To This Post Topic: Coil & Wires for Electronic Ignition
    Posted: 26 Jan 2010 at 6:09pm
I recently  installed electronic ignition in my WD45.  Now I would like to replace the coil and plug wires and I'm looking for suggestions for manufacturers/vendors that would give me the best bang for my buck, for a working (part time anyway) tractor...
Thanks in advance for your help!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:59pm
ck with jim danforth at ok tractor in mounds oklahoma,he sells the cd unit and is very knowledgeable as to what you need.i have brought 3 units from him and am thoroughly pleased
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:00pm
If you used a Pertronix module, I would use their "Flamethrower" coil. That's what I used on both my CA and Oliver 60. I also opened the plug gaps to .045. I also used Borg Warner plug wires. I forget what application I got them for, but it was a 4 cyl engine with a separate coil. If you're going to have the extra ignition voltage available, might as well make use of it.
Ira View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ira Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:21pm
Steve at B&B Custom Circuits can hook you up.
This page was generated in 0.042 seconds.
