Coil spring bottoms out |
3rd generation
Topic: Coil spring bottoms outPosted: 19 hours 28 minutes ago at 12:31pm |
Allis c coil spring with shock. I’m 210lbs and this spring bottoms out. What’s my solution?
Coil over shock absorber to gain more tension or is a newer coil spring stiffer. |
Posted: 10 hours 5 minutes ago at 9:54pm |
A new shock/spring assembly will be better than what you have. That's what coil springs do over time......flatten out. If it has an slot adjustment, move it as far to the rear as possible.
Edited by DrAllis - 9 hours 52 minutes ago at 10:07pm |
Les Kerf
Posted: 1 hour 59 minutes ago at 6:00am |
I put an old air shock on the seat of my 1941 Johnny Popper. I'm about 100 lb heavier than my grandson so we can adjust it to suit our needs.
