clutch
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: clutch
    Posted: 30 Oct 2016 at 2:18pm
Is it a good idea to store an allis b over the winter with the clutch pedal locked  down so the plate doesn'tget stuck to the flywheel?
John
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 3:16pm
I never have.   Just push it once a month you'll be fine.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:25pm
I never have -- had them set for years and not stick.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:58pm
I've never had a problem with my tractors since I've had them.
When I got my 8N it was stuck, but it had sat for 30 years though.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:04pm
If you don't let it get wet it will never stick.  Even then only one off season, I wouldn't ever worry about it.  By having the clutch depressed for that long of a period, I would be slightly concerned about reducing the spring force on the pressure plate springs a little.
Still in use:
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:35am
I'm with Orange Blood. I'd be more worried about compressing the springs that long than the clutch sticking.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:44am
Well, I've had two or three tractors sitting in the shed dry, I thought, that ended up with stuck clutches in them. However, every time that happened to me, it was a very wet year and I really do believe they stuck from all the moisture. That is one reason I won't stand on the ground any more and start a tractor! Two different times I was actually on the tractors and it's a " holy chit" moment when the tractor takes off and you're not ready for it! LOL! At least I had the big door open at the time and the tractor headed the right direction!   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:41pm
Thanks, i wot worry about it then
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
