Changing WD-45 to solenoid start.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: Changing WD-45 to solenoid start.
    Posted: 19 hours 39 minutes ago at 6:28pm
My starter is at a shop getting the lug replaced with a threaded lug. I'm going to use a push button start and solenoid. Question is where do you mount the solenoid and the push button? Unlike the B's and C's there is no metal tool box in that area. If someone has a pic or a diagram that would be nice. Thanks
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 54 minutes ago at 8:13pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 39 minutes ago at 10:28pm
You could just use the start position on the key.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 8 minutes ago at 5:59am
On my WC that I did the same conversion to, I “hid” the solenoid inside the headlight mounting pan under the gas tank. Years ago I converted an Autolite starter for my C and the shop mounted a small cylindrical shaped solenoid right on the starter using the tapped holes that held the original mechanical switch.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 40 minutes ago at 6:27am
Thanks for the pics and ideas
