Canopy or tilt up door on lean to
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Topic: Canopy or tilt up door on lean to
    Posted: 26 Jun 2026 at 12:30pm
Anyone do a canopy or tilt up door on a lean to? I have 15 ft 6 inch by 8 ft 4 inch high openings I want to close in winter with the picnic tables and other thinggs stored. A sectional garage door 8 feet tall does not work because the inside is just over 7 feet deep. Probably be a do it yourself design since you see very little of these doors in the US.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 12:51pm
you got room for a SLIDER ??  two doors 8 ft wide that overlap 6 inches would work... and you can build yourself out of 2 x 4 frame and 1 x 6 or plywood face.... have seen some use roofing tin on the face also..
Edited by steve(ill) - 26 Jun 2026 at 12:52pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 3:46pm
Son built a 10 x 10 door that swings up and becomes a extension roof into shop . Hinged at top and has slides inside to hold open - only problem it needs to be raised from inside
