Calling All Diesel Techs (Update)
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: Calling All Diesel Techs (Update)
    Posted: 15 Nov 2016 at 6:09pm
You may have seen the  previous threads of mine about trying to get a 3cyl. diesel Kubota B7100 running. Well, it still won't run. The injection pump was looked over by an expert and found nothing wrong. The injectors were tested and were good. Clean fuel flowing through all lines. Glow plugs are good. It will not start on ether or brake cleaner. The engine seems to have good compression as I have held the palm of my hand over the intake manifold while cranking and it sucks my palm in. I haven't checked the compression officially as I don't think that's the issue. The pump shutoff is purely mechanical, so I know when it's on or off. What am I missing here guys?
-Slim
Edited by Slim - 22 Nov 2016 at 4:38pm
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:52pm
Do you get any white smoke out of the exhaust when cranking it?
cbr_fx4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbr_fx4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:55pm
I have a small yanmar loader tractor with a 2 cylinder diesel. If you run it out of fuel no amount of pulling or ether will get it running. There is a small bleeder screw on the fuel pump or filter head can't remember which. Bleed that and it starts right up. Yours probably has something similar.
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:05pm
Yes, it puffs white smoke when cranking.
I'll try to bleed from the filter head and see what happens.
-Slim
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:06pm
Those PFR systems are very tough to get bled. Leave the lines loose at the injector ends, and keep bleeding until you get fuel there. Might help to bleed to the pump first. They pump so little fuel, it's really hard to get the air out.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:05pm
If it puffs white smoke when you roll it over, then i'd say you are getting some fuel there. I would be getting a more accurate compression reading. If it won't fire on either or brake kleen, then you have mechanical issues somewhere.
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:06pm
What's the back story? Did you buy it this way? Or did she up and die when running?
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:15pm
Check compression, make sure their is no remotes in demand. Have replaced bent rods in these little engines from either .
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:02am
not getting enough fuel.... Don't use Ether, use a little WD-40....
Bleed, Bleed, then Bleed until You Bleed....
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:07am
White smoke is low compression. Does it spin over fast? Hook it behind another tractor. Most diesels need to turn 800 RPMs to start.    MACK
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:54am
COMPRESSION!!!!!!!!!!! Is first thing you should have checked after seeing that it pumped fuel. If its not above 350#'s it won't run-start. 395 to 450 is normal. Also all glow plugs need to work! As other said pull it and see what happens. But I bet it doesn't have enough compression! Not hard to bleed! Bleed first at hose-fitting going into pump, and crack a line on injector. We sold hundreds of them and were a Great Tractor. But like any engine some get neglected! And they do wear out!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:13am
what farmtoy biulder said those glow plugs have to work and if you used ether and you didnt ether lock it,   it problley doesnt have enought compression do leak down test after compression test to find out were compression is going
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 12:31pm
Sounds like you demonstrated that it has vacuum. Doesn't tell you that it has decent compression. Should start by pulling it, though....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 1:01pm
If it won't hit on ether in the intake, base mechanical problem. Not enough compression, not enough heat to ignite the fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 1:04pm
Pull it fast enough to spin the engine 1500 RPM or so and it should eventually start. Once running, then if you continue to have starting issues, run a compression test on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:27pm
Another option is to go over to the kubota forum, and ask them, there.  They might be able to better explain the bleeding procedure... there is usually a screw on the pump and sometimes a vacuum bleed assist screw, that uses engine vacuum to aid in pulling fuel to the pump.  If you ain't got the compression, though, it ain't gonna start...
http://www.orangetractortalks.com/forums/
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:36pm
Glow plugs are good. Just checked compression and it is around 150 which is crap. Looks like a rebuild.
-Slim
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:50pm
What rpm were you spinning when you checked compression?
Wink
I am a Russian Bot
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:03pm
I jus has a lady call me and say her lawnmower will not start. I went over and looked at it would crank slow and try to start. I tried ether still nothing. After a couple more times the starter was hot to the touch. I got a new starter and installed it turned over a lot faster and started on second try. I have had trouble on some JDs that did not start also and same problem engine was not cranking fast enough to start. But some engines will start even if cranking slow some will not.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 12:28am
I have an  Kubota L175 with a Woods belly mower. I found a lot of help on the orangetractortalks.com forum.
Bleeding my little two cylinder just about has to be done at the injector. It really helps if the compression release is working.
Have you adjusted the valves? Doing that not only helped with power, I think it started easier too.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 3:05pm
If the pump has been off, I would check your timing. May be 180 degrees off. Regardless, verify timing. Also may have a head gasket issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 5:14pm
These pumps can't be put on 180 out, it just sits down in the block, the camshaft and governor stays on the engine. They are called PFR pumps. I'm closely following this since I've got a local guy in the same situation. Had me go through pump and injectors, and it will almost start. One glow plug was no good, so I told him that could make the difference, plus getting the cranking speed up some more. We have plenty of fuel delivery, it was running black fuel out the exhaust a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2016 at 6:10pm
Also, in cold weather, starting some of these little diesels can be a real pain.  Especially if you don't have a 'lectric preheater, on 'em.  I have a trick for that, too.  Take a single burner coleman gas stove, or radiant tent heater, and slide it under the oil pan, and let it warm up for about 45 minutes.  Don't do it on a oil leaking motor, though, LOL...Evil Smile
These old gas heaters can be bought cheap, at yard sales(I never paid much more than $20, on mine) or auctions...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 12:29pm
Thanks for correcting me Ed. I guess all Orange tractors are not the same lol. I shouldn't have chimed in on a brand that I know nothing about. Plus being newer as well. Sometimes I just can't help myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 12:51pm
No sweat Robbie! You're just trying to help. Those compact diesels are in a world of their own.
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 3:59pm
So I ended up pulling the head on the tractor to inspect the  head gasket as that was the only thing I could think of apart from bad rings. Head gasket was good. Cylinder #1 was clean and from what I could tell looked like it was burning fuel correctly. Cylinder #2 was dirty and had a "chip" out of the edge of the piston head. Cylinder #3 was filthy. Probably zero fuel being burned in that chamber. Looks like new rings and a piston I guess.
-Slim
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 4:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 5:47pm
When you put it back together, don't lose the oil pipe seal ring, that comes with the HG...
