CA Valve Spring Specs
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Valve Spring Specs
    Posted: 21 Oct 2026 at 1:11pm
Ive finally gotten around to diagnosing the misfire issue. Im measuring valve spring tension and none seem to be as expected. The stongest one is 55psi and one was only 35psi. The head rebuild was supposed to take care of that. Ill measure again after i research my technique...i bought an on head tool. It seems easy enough to use. I & T says 55-65psi to 1 5/16". One source says 70 psi but none approach that.
Edited by dfwallis - 21 Oct 2026 at 1:59pm
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2026 at 8:26pm
Appears that the tool cant accommodate the wide rocker pushrod to valve spacing. Ive enquired to the manufacturer if additional spacer inserts are available. Unfortunately, i think that will make the readings worse not better...lever arm pivet point is presently behind the valve which means it requires more force to compress the spring
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2026 at 4:11pm
The tool vendor indicates that ill have to calibrate the tool by installing a spring of known value then adjusting the pivot length and then measure the other springs. Not how i assumed it would work, but makes sense...they're sending additional spacers...the tool design assumes modern racing engines and didn't anticipate such long rocker arms. To start, ill assume the strongest spring is in spec and see what the variation is.
Edited by dfwallis - 22 Oct 2026 at 4:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2026 at 4:24pm
I believe ive found a significant issue with cylinder 3 exhaust rocker. When you remove slack and aren't careful about applying a light side force, it twists slightly. Then if you measure it, its in spec. However if you are careful to remove slack by applying perfectly in line force, it only has .003 clearance. Not good. Ive reset the clearance for the inline movement and will see how it runs. Unfortunately, i left the key on and ran the battery down and its taking forever to charge. Several rockers are similarly worn. I had assumed the rebuild checked all that but apparently not. Im probably going to buy a complete new set if this helps. With so much wear, when the push rod contacts it, the rocker again twists.
Edited by dfwallis - 25 Oct 2026 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2026 at 4:36pm
here is a photo of the rocker arm shaft with the rockers installed... are you saying the rocker arm BORE is worn and it wobbles on the shaft ?   I have never had that problem....(maybe they wobble a few thousandths and i have never considered that a problem ???)....  I have never checked the spring tension either.. only problem i have noticed is the rocker arm pad that sets on the valve is not always centered on the valve.. Have seen serveral that are way of center... but dont seem to hurt anything..
Edited by steve(ill) - 22 Oct 2026 at 4:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2026 at 4:40pm
here is a picture of one HEAD that had a bad freeze plug.... look at the two valves and their rockers and you can see they are OFF CENTER.... That seems to be very common on these old engines..
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2026 at 5:22pm
Both the rocker and the shaft have deep wear grooves...when it twists, the contact point can slide and cant 1/8 inch. Only one has this weird behavior...
Edited by dfwallis - 22 Oct 2026 at 5:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 9:21am
That odd rocker arm behavior was the problem. Ive not seen it run this smooth since the 70s. It will need a tuneup again though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 9:23am
I was afraid id burnt a valve, but doesn't seem so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 9:24am
A quick cranking compression test would verify that or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 10:16am
128psi
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 10:38am
As compared to the other three?? looks fine to me, but how are all of them ??
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 10:49am
Glad you found it Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 12:09pm
Theyre all near 130
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 12:29pm
Good to go !!!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2026 at 5:31pm
Interesting, and thanks for sharing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2026 at 3:17pm
i retract this statement. Many of the rocker arms exhibit this twisting when the push rod applys force, most just not as severely as cylinder 3. So i think several cylinders are dynamically changing clearance due to lack of a clean circular arc motion...The x agco dealer is working on a parts quote. What started my research was that last trip it suddenly started having a strange buzzing noise in the exhaust. It sounded to me like a valve stuck partially open. Im not an expert by any means, just what it sounded like to me. After it warmed up it started missing severely on one cylinder. Im glad i stopped it quickly, although it turned out non-disasterous.
Edited by dfwallis - 25 Oct 2026 at 12:13am
