CA surging
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA surging
    Posted: 19 Dec 2017 at 10:19am
I have rebuilt carburetor, tuned up, adjusted valves and still have a surge when the tractor is revved up. It calms down and runs right after the initial surging. The throttle rod has a small hole in it, is this for a spring? My WD45 has a light spring on the throttle rod to the carburetor, did a CA as well? Was it to prevent surging? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 11:00am
yes, it should have a spring on the carburetor rod.  I don't have a CA parts book, but the part number for a D10 is 232020 which is probably the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 1:37pm
Other causes for a CA’s engine surging are: improperly adjusted governor cross arm an running lean due to oxygenated gas. I’v found that the main jet needs to be drilled out a tiny bit for them to run righ on our mandated pollution control gas.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 2:11pm
I agree with Paul!
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 7:36pm
Anti surge spring will more than likely fix your problem. $12.00 from most of the suppliers on this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 7:44pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:39pm
Ditto!
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 9:10pm
thanks, Charlie.
looks to be a useful site.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 9:14pm
I have one ordered and think it will solve my problem. Thanks to all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 9:18pm
One end attaches to the hole in the rod.  The other end goes up and attaches to one of the manifold studs.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 10:15pm
The spring came today. I put it on, took care of the surging problem. Runs like a dream and ready for mowing season! Thanks to all!
