CA rocker arm torque spec |
rustyorange45 ![]() Silver Level Access ![]() Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 397 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Dec 2017 at 9:07am |
What is the torque spec for a CA rocker arm assembly? The four nuts holding the pedestals to the head. Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
I have always assumed the studs are grade 5 and torqued around 20 foot pounds or slightly more. I have a box of the aluminum stands that were broken/cracked that I also assumed they were over tightened because of how they were cracked. Torque standards for a 3/8" grade five bolt is 25 foot pounds. I have not found any of the stamped steel stands broken.
![]() Edited by Dick L - 17 Dec 2017 at 9:55am |
