CA not charging at full rate
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: CA not charging at full rate
    Posted: 12 hours 2 minutes ago at 9:51pm
6 v original system and generator. Struggles starting, New Battery in 2025, reads 6.15v at half throttle when running. I believe it should be over 7 with charging from generator when running. Tested the generator at a shop and they said it is good, check the grounds. This is a new to me nicely restored tractor so not sure on all the wiring. Im no electric expert but understand the basics of it. Attached are a couple pics, not sure about the spare wire there in the console. What should I look at next?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 31 minutes ago at 10:22pm
Pull the light switch fully out to make it full charge ?? or adjust the third brush position inside the generator dust cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 54 minutes ago at 6:59am
The operators manual tells how to adjust the 3rd brush and operate the charging system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 37 minutes ago at 8:16am
also , the light switch controls the MAX CHARGE... if it has some kind of problem, you could have a lower charge ... conntect a jumper wire with aligator clips, from the generator "F" terminal to the battery GROUND ( bypasses the switch) and see what happens...
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 23 minutes ago at 8:30am
That light switch is completely different than the switches on my CA, Model C, and WD. I'm not saying for certain that it is the wrong switch, but it does need verification that it can actually provide the connection to ground to enable the field on the generator.
Has this tractor ever charged correctly since you have owned it, or is this a recent development?
Edit: Does that black wire that is dangling loose lead to the generator? You could test it with an ohmmeter to find out
Edited by Les Kerf - 1 hour 19 minutes ago at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 minutes ago at 9:50am
Looks like it doesn't have the correct light switch to be able to do a low charge and "High Charge". So, that black wire probably has to be grounded to make the gen charge at all and then it would be high charge only.
