CA front tires
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA front tires
    Posted: 15 Jun 2022 at 8:44am
I just ordered a pair of Carlisle implement tires for my CA. It is used for mowing my yard and with   three rib front tires it would cut into the lawn when turning sharp. I am hoping with the implement tires to avoid this. Does anyone else have implement tires on their CA and what do they think of them? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 9:00am
Not implement tires but I have 'trailer' tires on the front of my CA-1. Did that for the exact same reason as you. Yes, it helped a ton! The tri-ribs cut up the yard pretty good, car tread does not, (as bad).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 10:25am
I modified D15 rims and put 6 x 16 inch implement tires on my B with WOOD mower... Works great in the grass.
Edited by steve(ill) - 15 Jun 2022 at 10:29am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 12:00pm
Have implement tires on the front of another color. Much better on grass
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 4:32pm
Thanks for the responses. I had a pair of foam filled three rib tires on it which I switched to my wide front CA. I use it for brush hogging and everything else. Would it be wise to put Slime in the new front tires or just leave them alone. I put Slime in my zero turn mower and have yet to have a flat.
Edited by rustyorange45 - 15 Jun 2022 at 4:33pm
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 6:56pm
IBWD, those trailer tires you have on your CA?? Can you tell me what size they are? And the rims?? Did you have to alter them to get them to bolt up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 9:12pm
the rims on a B-C-CA are 15 inch, 4.5 inch bolt pattern... normal rims are 3 inches wide for 5 inch tire............. You could put TRAILER RIMS on that were 5 x 15 inch with 4.5 inch bolt pattern and then use 6 -7-8  inch tires ( 175 - 205 mm) .... or similar  ...... CENTER HOLE 2-3/4 inch or bigger..
Edited by steve(ill) - 29 Jun 2022 at 9:33pm
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2022 at 5:50am
Thanks Steve,you answered the question I had about the rims
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2022 at 10:43pm
tap the right  or left brake a little when turning hard will take a lot of the push out of the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 8:29am
Tom, they bolted right up. Guessing Steve got your question answered. I've been on vacation in Canada and didn't have internet or would have replied earlier.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2022 at 11:05am
Thanks, I'll grab a couple of them for mine
This page was generated in 0.183 seconds.
