CA Clutch
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: CA Clutch
    Posted: 16 Oct 2011 at 9:38pm
I have a 1952 CA SER #21868, that the foot clutch gave out on me.I was looking for prices on ytmag and they have two different size of clutchs, one is a 8.5in and the other is a 9in, both are marked for B,C,and CA. Sandy Lake is the same way with the size and both are marked for B,C,andCA. Is there a SER# break that they put different size of clutchs in the CA? I need to know so I can order one, and put her back together again. Thanks Josh
Edited by Josh Day - 16 Oct 2011 at 9:39pm
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 9:43pm
If it were me, I would call them in person and give them your serial number and they will send you the correct parts.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 9:47pm
I did with Sandy lake and they asked me what size I had. I just started to tear it a part so I can't measure it yet.
Edited by Josh Day - 16 Oct 2011 at 9:49pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 10:45pm
The CA used the 8.5" clutch as did the B & C with electric start. The 9" clutch was used on crank start models. There wasn't enough space to add a ring gear so the went to a 8.5" clutch.
The D14 and D15 use a 9" clutch. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 6:05am
All right thats what I needed to know. Thanks
Edited by Josh Day - 17 Oct 2011 at 6:05am
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 1:16pm
   I find it odd that Sandy Lake does not know this ? They are usually very knowledegable.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 7:57pm
I know, Brenda asked me what size I had and Bill thought it had the 9in clutch. I'm glad I got a second opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 10:14pm
Actually some of the crank start B models used an 8.5" clutch.
I've had 8 B's 3 C's and 4 CA's, 1951 and 1952 , apart and this is what I found on every one of them. Some of them had a solid disk and some had springs in them.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2011 at 10:15pm
Bob
